Results 1 to 10 of 15
Thread: Washer level sensor hole size???
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    confused Washer level sensor hole size???
    Hi guys n gals
    Can anyone tell me what size drill bit I will need for the Washer level sensor hole???
    Got all the bits and have even sprayed the headlight washer covers but noticed my new reservoir has not got a hole for the level sensor.
    Largest drill bit I have is 15mm but thinking that won't be big enough
    Will hopefully get started with the install late next week but just trying to be better prepared
    Many thanks
    Damo
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    22mm springs to mind. I think Ian_Highlander drilled his on his old saloon might be worth pm'img him. BTW when you say your new reservoir has not got a hole for the level sensor, is it a 5.2Lt one? Should come with a hole id have though.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I can't remember, I know I didn't have the right size so ended up drilling several small holes and filing it out by trial and error.
    (Damn you've got a good memory DasArab lol)
    The bigger reservoir should have the hole already though I would have thought, I've got one sat here with all the headlight washer bits waiting for me to fit them and that has both pumps and a sensor in it.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    LoL, dont bother pm'img him hes here.
    Year : 55
    Mileage : 92,000
    Cheers for that Ewan, didn't think I'd have the right size drill
    The reservoir I bought was 5.6L (pic below) and deffo doesn't have the hole drilled
    Damo
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    My big washer bottle wasnt predrilled with the hole.. i had to make it my self.. but i used a 15 mm drill and the a dremmel to make it larger.. until it fitted.
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by Ian-Highlander View Post
    Might end up doing the same Ian Was thinking of buying one of those step drill things but the only one I can find is a sealey that goes up to about 30mm for £30. Which is a bit much to only use the once.
    So might follow your advice and get handy with the old file
    Damo
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by kenp View Post
    Thanks Ken, will have to get inventive with the tools.
    When I get round to removing my old reservoir, I'll take the sensor out and get the vernier calipers on it and found out the exact size. It may help others if they encounter the same
    Many thanks
    Damo
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by Damo77 View Post
    Damo
    Ah cool. I take it you got the rubber grommet that fits to the reservoir? What I would do is take a steel ruler and measure the width of said grommet. Then measure the depth of the gap that seals the grommet to the hole in teh reservoir. Then remove the depth from the width to give you the size of hole, and just to be on the safe side make it 1mm less.
    Year : 55
    Mileage : 92,000
    Hopefully it will just be a matter of taking the sensor and grommit out of my existing reservoir and swapping it over to the new one in the pic.
    Was just trying to prepare in advance really to save taking the bumper off and finding that my drills weren't big enough then having to put it all back together to go out and buy one
    Think I'll try and get the daughter round when I start the job, if it goes pete tong, I can get her to drive me down to the hardware store lol
    Muchas gracias mate
    Damo
  1. Washer Fluid level sensor???
    By Ian S100 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2016, 00:15
  2. Washer bottle level sensor location
    By EddyPole in forum Vectra C / Signum Troubleshooting
    Last Post: 21st September 2011, 20:15
  3. For Sale: Washer Bottle Level Sensor
    By Das in forum Parts for sale
    Last Post: 26th August 2011, 14:14
  4. washer sensor hole size
    By mhvcbv in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2009, 21:36
vectra c wash fluid sensor location
