Thread: Steering knock....suggestions???
    Dec 2011
    Midlands
    Default Steering knock....suggestions???
    All,
    Looking for a few ideas on a problem on my 55 2.2 Direct.
    Basically when I rock the steering wheel back and forward I am getting s knocking sound coming from the nearside front. I knew there was play in the track rod ends so have swapped both out today and while the steering now feels very sharp I still have the knocking noise. I have also changed the suspension drop links, discs and pads all round today...been busy
    There does not feel as if there is any play in the rack...it's tight now that the track rod end has been changed...so does anyone have any suggestions on what to look at next? Was thinking it might be the front wheel bearing on the way out or possibly the suspension top mounts....I can feel it through the wheel knocking back and forward. Any advice or suggestions would be greatly appreciated.
    Steve
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Top mounts mate
    Dec 2011
    Midlands
    Are they a common failure point? Car has just ticked over the 44k miles now. Are they a pain to change?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Fairly common yeah.
    Easy enough.
    Take front strut out.
    Compress spring slightly
    Undo 21mm nut
    Remove and swap top mount and bearing.
    Easy as that.
    Looking about 1 hour to hour and half with out air tools
    Dec 2011
    Midlands
    Well does indeed look like the suspension top mounts...rocking the steering wheel back and forth I can see the top of the NSF moving around....bolt has a good 1mm of movement.... OSF is rock solid but suppose I should just change them both out as likely other ones worn too.
    Where's the best place to buy these?
    steve
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    I got genuine one from Uni part for £57 each
  1. knock from steering
    By marktaylor in forum Vectra C / Signum Troubleshooting
    Last Post: 4th July 2012, 08:53
  2. steering knock
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2011, 18:25
  3. knock on steering help ?
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2009, 20:18
  4. Steering knock sorted!!
    By shrekster in forum Suspension, Wheels & Brakes
    Last Post: 20th March 2009, 14:35
  5. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
