Thread: help needed
    Jan 2012
    essex
    Default help needed
    hello threre i am a new member so if i get it wrong dont all shout at once,ihave just bought a signum 1998cc year2003. it was missing when i bought it but was fine on motorway work so the first run was to see family in liverpool from essex running was good three hours but running local its missing and engine shakes and stalls had in the shop three times all come up with something but not the right thing, trying to find a manual for this car but thats not easy hope someone can help thanks rayeg 1935.http://www.vectra-c.com/forum/images/smilies/smile.gif
    lincolnshire
    derv or petrol ??
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    RM postcode so not to far from me ... as above are you a deisel or a 2.0T petrol .
    guessing a deisel .
    18 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    guessing a deisel .when it went into the garage did they get any fault codes ???????
    Jan 2012
    essex
    Hi its petrol CODE 300.
    South east
    Ok, let's clarify, you have the 2.0T PETROL (yes?), that's the Z20NET then. That's a Saab-developed engine, so the Haynes manual for the 2002- Saab 9-3 covers it. As for your fault, start with the easy stuff first, change all 4 spark plugs and use the correct replacements, which are NGK PFR6T-10G. Even if the car has been serviced regularly, the plugs don't get changed at every service, so sometimes they get missed out too often. Have a good look at the condition of the plugs you remove, to see if one or two look worse than the others, that might imply the ignition coil for that cylinder is failing. Fault code P300 just confirms that it's most likely to be plugs/coils etc.
    Jan 2012
    essex
    thanks for the tips your right on all counts but the first garage charged me for new plugs but i will pull them out the last garage told me it was one coil pack putnew one in but stayed the same but good garage said no charge sent coil back.
    South east
    There's no coil "pack" in this engine, there are 4 separate coils, so only one would have been replaced, and if it was put on a cylinder that didn't have the problem, then it won't have helped.
    Oct 2011
    Essex
    If you want something in your hand, there is a Signum buyers guide in this months Car mechanics mag, might be worth a purchase?
    Jan 2012
    essex
    i got onto vauxhall spares in thurrock who said they had nothing listed for this car.
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
