Thread: Cruise control keeps turning itself off
    May 2011
    Nottingham
    Default Cruise control keeps turning itself off
    Hi,
    Having problems with my cruise control at the moment. Driving home from work and realised, more and more cars seemed to be drifting past me...cruise control had simply turned itself off!!. Put it back on and it lasted for about 5 seconds and did the same. Tried it a couple more times and the same thing happened..weird!.
    Anyone had the same issue?
    Mike
    Lancashire
    yeah i have took the stalk out with the paperclip method and cleaned the terminals with contact spray and the ones on the stalk as well , also used a piece of bent wire to lift the little wire connectors inside the housing , it has almost solved it but i am still having a problem when i indicate right it knocks off , every other way its perfect , think i need to take it out agian and try some emery cloth on the stalk connecting points see if that works
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Also clutch switch adjustment can cause it
    WGAF#5
    There is a clutch spring that can be replaced ... Have a search for a thread by porkballs29 who details the problem and the parts info
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    Has your floor mat slipped forward and up under the brake pedal? This happened to me I thought I had a major annoying problem but thats all it was switching the cruise off. It appeared to be actuating the brake switch.
    May 2011
    Nottingham
    thanks for all tips fellas, will be spending some time on it this weekend!
    Chelmsford
    Many problems with the Vec cruise control... I've had:
    1. clutch spring failure (recall on some models, but I had to buy the mod-spring from VX. 2 minutes to fit)
    2. dirty connections where the stalk connects with the steering column. As someone has said, it's a case of taking the stalk out and giving a blast with contact cleaner.
    3. sticky buttons on the stalk. Still get this now and it's a pain in the bum.
    Chelmsford
  1. Turning Traction Control Off
    By Kev_G in forum Handling & Braking
    Last Post: 22nd February 2011, 15:50
  2. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  3. Help Me Cruise Control
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 15:54
  4. Cruise Control
    Last Post: 5th January 2008, 22:37
  5. turning off traction control????????????
    By dervdoc in forum Suspension, Wheels & Brakes
    Last Post: 2nd March 2007, 19:27
vectra c cruise control
vectra c cruise control keeps turning off
vectra cruise control keeps turning off
cruise control knocks off
vectra c sri cruise control keeps turning off
vectra c cruise control fuse location www.vectra-c.com
common cruise control problem vectra c
cruise control vectra
why does my cruise control keep turning off
vauxhall astra cruise control turns itself off
vectra c my cruise control turns itself off sometimes
vectra cruise control cutting out
vectra cruise control turns off
