Results 1 to 10 of 11
Thread: Rear upper control arms excessive play?
    Regular Member paul.sessions's Avatar
    leighton buzzard
    Default Rear upper control arms excessive play?
    So I know the check grab the top of the wheel while car is stationary! And give it a tug. Yes I have movement there, but what is classed as the Mot failure excessive play? Where is the line drawn? Can You guys go and check your rear wheels too to see if you have play, or am I just being paranoid? Lol
    South east
    It will adversely affect the handling long before it becomes an MOT issue - the Vec-C can get to the stage where it handles like a bag of bolts because various bushes are worn, but still pass an MOT. Most people who've replaced the banana bars have done so because the rear doesn't handle correctly, rather than just doing it because the MOT tester failed it.
    It is classed as MoT failure where the bush has completely worn or failed
    Typically this is where little or no effort is required in order to get a metal to metal noise
    Northampton
    Engine : A20DTH
    Mileage : 88000
    worn ones will affect handling and tyre wear so get them changed regardless!
    leighton buzzard
    yeah was trying to get out of changing them, didnt fancy that fiddly bolt. but decided as the weather was nice, managed to do both sides in a couple of hours.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    They will metalic knock not just move. Wont help tyres wear!!!
    leighton buzzard
    yeah i had a knock occasionally and quite some play in them, the car felt like the rear end was wandering.
    Apr 2009
    ayrshire
    The signum feels shocking right now, when it hits a small bumps on the road the backend skips around, steering feels light untill it all settles down. Bannannananannnana arms? 2006 on 65K miles.
    leighton buzzard
    mine was wandering like mad too changed them now, 2003 55k
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by gilmour182 View Post
    Backend skipping around when hitting bumps could be rear upper control arms (banana arms) but it's more likely to be rear shocks.
  1. Rear Upper control arms help
    By enjoy_life27 in forum Suspension, Wheels & Brakes
    Last Post: 15th January 2013, 23:04
  2. Replies: 41
    Last Post: 6th September 2012, 20:38
  3. rear upper control arms
    By keggy77 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2012, 02:13
  4. Upper rear control arms...
    By tommychimp in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2010, 17:51
  5. rear upper control arms
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 24th October 2008, 18:29
