Results 1 to 10 of 18
Thread: Oil misting in intercooler pipes....
    Sep 2010
    norfolk
    Default Oil misting in intercooler pipes....
    Gents, in the quest to find reasons for my late 2005 y30 shaking like a crappin' terrier. i noticed today that the two hoses to, and from the intercooler have a fine mist of oil in them, as does the mouth of the turbo. Problem???. Also the main boost pipe from the i/c to the air intake plenum "bulges" when revved at idle...is this normal?
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    The oil is normal mate. A small amount anyway.
    as for the pipes blushing how much do they bulge? They should fill up a bit and harden due to the air pressure at boost
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Double post
    Sep 2010
    norfolk
    it swells visibly by about 10-15 mm across its diameter.
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Hmmm Yeah that is quite a lot.
    do you have a way to check what it's boosting at?
    On another note for the shaking Have you got any noise coming from DMF?
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Double post is starting to break me
    Sep 2010
    norfolk
    Only noise is a slight rumble on release of clutch pedal. Much like good old release bearings in the good old days before laptops overtook spanners....no other clutch issues, or noises.
    Sep 2010
    norfolk
    Sorry no, now way of telling what boost pressures might be.
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    As vibration can be caused by failing dmf.
    What's the milage on the car?
    Are all injectors firing ok etc?
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
  1. Intercooler pipes.
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 23rd September 2012, 08:59
  2. Replace 2.2DTI intercooler pipes?
    By kenno31 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2012, 11:14
  3. 2.2 dti intercooler pipes
    By peadar in forum Diesel Engine related
    Last Post: 3rd March 2011, 21:57
  4. 2.0dti intercooler pipes collapses!
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 18:22
  5. Intercooler misting/spray
    By a18nmk in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2007, 22:14
intercooler misting oil
