Thread: What's in Your Air box?
    Regular Member wotsthestory's Avatar
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    Default What's in Your Air box?
    Just put a panel filter in my car and did the air box mod and was greeted with this.
    This was worse than my previous vectra, yet still had a fag butt in that one. How does this happen?
    Spent some time clearing that lot out, did the air box mod and installed a K&N Panel Filter. Now a bit smoother, unsurprisingly.
    So the question is, what have you found in your air box on opening?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    same in mine....
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Mine's clean apart from the K&N filter, I check it now and then.
    Sodding Typical on Sea
    Looks about normal, but,, I didn't see any badger's sharks or dinosaur's so I guess Col has yet to work his magic on this pic
    Jul 2010
    stourbridge
    Testament to the Vectra's contribution to cleaning up the environment.
    Regular Member rockhopper's Avatar
    Scotland
    Just makes you think. Even with a 'full service history' you find years worth of crud in places it shouldn't be if it had had an air filter change. Mine was not quite as bad but still way past the acceptable amount when I changed it. Obviously hadn't been changed in years despite the history.
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    checked it not long after i got it, there was a fag end and a bee in there!
    vaccuumed it out and its not so bad since, dont think it had been cleaned for 55k miles before then!
