Results 1 to 2 of 2
Thread: connection on the temp sensor 1.9 (120)
    Regular Member tosh23's Avatar
    HULL
    Default connection on the temp sensor 1.9 (120)
    vectra 1.9 cdti 120 2007 estate
    Ive changed the temp sensor/sender that sits on the thermostat housing, sending water temp information to the ecu.. (green plug)
    Whilst changing the unit I noticed that the connection on the plug ( permanent OE wired) can turn 360 degrees. I know the plug only goes into the green sensor one way but the top can spin freely.
    Is it designed to spin freely or has it broke ? Many thanks Tosh
    HULL
  1. outside temp sensor
    By andy_richmond in forum Troubleshooting
    Last Post: 30th September 2012, 14:09
  2. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  3. Where's the outside air temp sensor??
    By cooky in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2010, 22:32
  4. Temp Sensor
    By JSYSH466Y in forum Styling
    Last Post: 20th February 2009, 00:41
  5. Temp Sensor
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2006, 22:45
