24th November 2013, 18:52
#71
hiya mate....
Originally Posted by
Silentknight2
I have this rattle but mine is permanent and not only on start-up, only had the car 6 months. I've checked the service book and it has never been serviced by Vauxhall. So unsure what oils have been used. Ive been told by the dealers that the cam shaft gear wheels need changing for £550.. As this noise is now permanent would removing the solenoid filters, doing an engine flush and oil & filter change with 0 - 40w fully synthetic oil help at all, or is my engine actually passed this stage? Thanks.
The 0 40w is the oil that GM GROUP use on the engines when they are build in the assembly line... Vauxhall forget to mention on the Z18 XER To use the 0 40w engine oil on the cold countrys like, the UK, and others countrys in north Europe... and the 5 30w engine oil to use in the countrys south Europe... I come from Portugal , and the oil used there on this types of engines are 5 30w coz of the weather.... I really hope that 1st you try my recommendation, coz might help u out... alote of people in the forums, have always the thing of question, and moaning about everything... so I will think that u should make yours maths in a simple way.... 0 40w arrives first to the camshafts, than 5 30w... and is more expensive than any others engine oils... the problems in the z18 xer engine is that in the uk customers put 5 30w oil, in the winter... that 5 30w only shoul be put in the summer, and 0 40w on the winter.... thanks for your time reading my post
24th November 2013, 20:17
#72
Hi Filipeu, I will definitely be trying an engine flush and oil change with 0w 40 oil before anything else.
25th November 2013, 14:54
#73
Liqui-molly 0 40w....... Castrol edge 0 40w......... Mobil1 0 40w....... Gm dexos2 0 40w...... Are the oils that they have recomended to me to use... The bloke of gm/opel told me to put liqui-molly engine flush, and the engine oil... So i think it worth u take is advise....
25th November 2013, 20:12
#74
All about oil in easy to understand lingo...........sort of.
http://www.upmpg.com/tech_articles/motoroil_viscosity/
http://www.upmpg.com/tech_articles/oil_bottle.htm
I recommend fully reading the information in these links.
27th November 2013, 14:07
#75
27th November 2013, 18:24
#76
Why are you typing in capital letters all the time, is your keyboard faulty ?
As I said you obviously didn't read the links I posted above from your reply,
or you did but don't understand whats written on the informative website.
So.............
The good thing is it your engine, your choice to put what you like in it when you like,
as your the one paying for it and as long as your happy that's the important thing
Have fun .
20th August 2021, 13:42
#77
Silentknight2
Don't know if you are still on here or not but if you are did you try it and did it work or otherwise. Ours has been rattling for years now awaiting complete failure but it soldiers on.The rattle disappears over 1500 rpm but returns on idle. I think a few people have changed all the timing gear only for the noise to still be there. I am thinking oil pump or low flow below the 1500 rpm.
Has anyone followed felippes advice and it solved it.
OR IS IT THE OIL PUMP. ASIF not done at the timing belt and gear change it has all to be done again. The oil pressure switch IIRC is hidden behind the catalysed manifold.
Pomeo
11th October 2021, 13:46
#78
Hi. Did anyone take any photos while doing this job? Or any how. 2s
11th October 2021, 14:18
#79
take photo's of what an engine flush and oil replacement or the cam-phaser replacement? why not look in the how-to's yourself? if it is there it'll be easily found through the index topic.
11th October 2021, 15:04
#80
northpole
Plus, this very issue has been spoken about quite a bit in the past few weeks. So I’m not sure why they have been missed and not used to help solve it.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
