Thread: Stiff Gear Change
    Feb 2012
    stafford
    Default Stiff Gear Change
    Hi all, I've just joined and I'm after a bit of advice. I have a 2005 54 plate Vectra 1.9CDTI 150 with a 6 speed manual box. Over the past few months the gear stick has become stiffer and stiffer but only side to side. I've checked the cables they seem fine it. It feels like the selector in the box is this common and what’s the fix.
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Try dropping the fluid and putting 2.4 l of fresh stuff back in
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Having the same issue. Basically down to changing the selector forks now ( having changed the cables and gearbox oil already). This seems to be the way forward after reading through some Alfa forums.
    Nov 2007
    lancashire
    cables can start to size, may be worth looking at these first.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Stiff gear change when cold - fluid changed
    By cont1204 in forum Engine & Drivetrain
    Last Post: 18th December 2012, 14:58
  3. Stiff Gear Change
    By John Bishop in forum Engine & Drivetrain
    Last Post: 1st June 2012, 16:43
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Stiff gear changes
    By James7 in forum Engine & Drivetrain
    Last Post: 17th April 2007, 19:45
