Thread: Coolant capacity? 2.2 Direct auto
    11 Post(s)
    Default Coolant capacity? 2.2 Direct auto
    Can someone confirm that it is 7.6 litres for the 2.2 auto direct engine?
    Changing the stat tomorrow and want to also flush out the system and replace the antifreeze with a new 50/50 mix.
    Thanks.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    7.4 for the Z22YH Auto according to Haynes m8. 7.6 is for the Z22SE Auto.
    11 Post(s)
    Thanks Rushy. I got the info from Autodata which says 7.4 litres for the manual transmission, 7.6 for the auto.
    If I put in 3.75 litres of antifreeze (50% of 7.5) then top up with water I don't think it'll be too far out.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I put 2.5L of VX antifreeze in then 2.5L of water then mixed the remainder in the bottle and poured it in as needed. You wont be able to get all the coolant out so its not going to be the full 7.4/7.6 bang on anyway.
    11 Post(s)
    Yes, I made that mistake years ago. Mixed up a 50/50 ratio of antifreeze and water, then had over 2 litres left over and I was left scratching my head as to why it wouldn't all go in.
    Annoying thing was, as there was only water left in the system from flushing through with a hosepipe, there ended up being less than a 50/50 mix in the system.
    That's why after I have flushed the system this time, I am going to add 3.75 litres of neat antifreeze, and then top up with water, so hopefully there will be a closer ratio of a 50/50 mix.
    11 Post(s)
    Job done, all made even easier with the drain plug on the rad that I didn't previously know about.
    Temp sits at 84 now though, instead of the previous 89 to 90.
  1. Coolant capacity
    By blackveccyC in forum Engine & Drivetrain
    Last Post: 14th July 2010, 15:57
  2. 2.2 direct auto oil
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2010, 13:32
  3. 2.2 direct auto help needed
    Last Post: 1st December 2008, 11:25
  4. 2.2 direct SRI Auto
    By old cruiser in forum Engine & Drivetrain
    Last Post: 8th June 2008, 17:37
  5. 2.2 Direct SRI Auto'
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2008, 19:03
vectra c 2.2 antifreeze
coolant in vectra 2.2 sri
vectra c 2.2 direct coolant change
how much coolant for vectra 2.2
signum 2.2 coolant volume
vauxhall vectra coolant capacity
