Thread: spring replacement afl light now flashing
    lanarkshire
    Default spring replacement afl light now flashing
    changed 2 rear springs on my vec now my AFL light is flashing do i need to take to stealers for reset ?
    lincolnshire
    are you sure you didnt damage the load level sensor while fitting the springs ??
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    If you don't disconnect the level sensor when you pull the lower arm down you can damage the level sensor.
    Odds on thats exactly whats happened. It happens fairly often when people with afl or xenons lower their cars or change springs. the lower arm drops and snaps the sensor arm off.
    Glasgow
    Putting the sensor under to much pressure even if there is no visible damage by not detaching it will damage it internally beyond use.
    lanarkshire
    so do i need to buy a new sensor then how do i check its been damaged and roughly how much?????
    Have a look at it, it may be very clear it's fubar. Or get the codes read.
    lanarkshire
    shall try reset the fault 2 moz and see how i go then phone my local friendly vx dealer for price of new one
    lanarkshire
    Thumbs up sorted
    problem solved took to local exhaust place put on ramp and found bracket not correct reset to correct position hey presto no more fault light
    cheers for the help
  1. Front spring replacement
    By maz in forum Suspension, Wheels & Brakes
    Last Post: 11th November 2012, 01:08
  2. rear spring replacement
    By flimbyx1 in forum Suspension, Wheels & Brakes
    Last Post: 19th April 2012, 13:30
  3. Irmscher Spring Replacement
    By honigstrauss in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2012, 17:25
  4. rear spring replacement
    By meathead in forum Suspension, Wheels & Brakes
    Last Post: 17th January 2010, 04:49
  5. oil can light flashing
    By jstal40024 in forum Engine & Drivetrain
    Last Post: 15th June 2009, 13:10
