Results 1 to 10 of 18
Thread: Biggest battery I can fit?
    Engine : 1.9 CDTi
    Default Biggest battery I can fit?
    Any idea what the biggest battery is I can fit to my Signum CDTi?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As big as the electrical load required and one which will not stress the alternator - obviously depending on the alternator rating (105A-hr?) so the largest battery the one which is closest to that amp-hour rating to be safe.
    Engine : 1.9 CDTi
    How can you stress the alternator.
    It will only give out its maximum output.
    Having a bigger battery will just store it for longer.
    Regular Member 2wheelstu's Avatar
    Feb 2012
    Warwickshire
    I just replaced the battery on my 1.9cdti. Assuming that the battery housing is the same on your model. I put a Varta F18 silver on. Purchased from battery2u for £95 inc next day delivery. It has 85ah with an 800 cold crank rating. Makes a huge difference to my cold starting. The silver range is designed for vehicles with lots of equiptment and aftermarket sound systems. The dimensions of this battery are 315mm x 175mm x 175mm. Fits perfectly. Hope this helps
    Feb 2012
    Warwickshire
    I just put a new high load battery on my 1.9cdti. Got a varta F18 silver for £95 including delivery from battery2u. 315mm x 175mm x 175mm. The varta silver range is designed for cars with lots of equipment and aftermarket sound systems. It is 85ah with 800 cold cranking. Hope this helps.
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Completely agree with Gaz, if the battery you install on the car is too high for the alternator it will cook the alternator - seen it so many times.
    The solution : if you want to power additional items like big audio system, etc then the correct way to go would be with a split charge system - not overly expensive and real simple to install and you can retain the standard unfried alternator and a happy standard battery powering just the car.
    Hope this info helps.
    lincolnshire
    im struggling to believe you can overdraw on an alternator , it will only give out what its meant too at any given rpm surely ?? i have fitted bigger than needed batteries on several cars without any problems
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by lee gsi View Post
    never mind
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by bembo449 View Post
    point taken
    But you can stress an alternator with excessive electrical load.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Nothing wrong with fitting a higher rated battery mate.
    I towed my caravan on the last Vec meaning it technically had 2 batteries and had no problems what so ever.
    Your not increasing the the load on the alternator as you are drawing the same amount of power as you did before.
  1. I have THE BIGGEST GRIN EVER!!! :-)
    By tanya_baby in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2012, 10:50
  2. The biggest thank you ever
    By bigmac in forum General Chat
    Last Post: 22nd April 2011, 13:26
  3. Biggest sub
    By chris fixter in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 00:24
  4. biggest RIP OFF ever!!
    By mat100edt in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2008, 15:50
  5. biggest alloys can fit
    By beefycol in forum Styling
    Last Post: 13th October 2008, 19:24
can you use a bigger power battery on vectra c
vectra c biggest battery that will fit
