Results 1 to 10 of 24
Thread: fitting a cd70 how long?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default fitting a cd70 how long?
    as above i just need some idea as i've changed radios before and there was never enough room for all the new wiring loom.i wondered if it was an hour or 2s work. i will have to fit new vents as i want the colour screen.
    finally are the cd70s worth the money i'm looking at £375 for all the bits ,screen,head unit ,cable, aerial, map disc and the vents
    thanks in advance mrk
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    OK, you need to drop the roof lining on the drivers side and rear, remove the drivers footwell cover to replace the aerial wire and aerial.
    The headunit itself is fairly straight forward BUT you may need to add an extra wire from the driver's footwell to the back of the CD70 for the GPS signal if you haven't got the right loom behind your dash.
    If the GPS signal wire is in your dash loom then it should only be 2 - 3 hours max, less if you are a dab hand at dropping the roof lining.
    Trim : improving
    Year : 06
    sorry for mis understanding i meant the little gps aerial that goes under the centre dash grille
    South West
    about 10 mins to put a gps antenna in the center speaker area and route the cable through to connect to the back of the CD70.
    The rest of the installation takes about an hour if its the first time you have attempted it
    Full Member RBH's Avatar
    Jan 2008
    Central Scotland
    101 Post(s)
    Vehicle : Insignia VX Line
    Trim : SRI
    Engine : 2.0 CDTI
    is the roof aerial model specific for the cd 70 or does the cd 30 aerial do the same job??
    South West
    different mate. The CD70 is just a base for the aerial to screw into where as the CD70 incorporates a GPS antenna as well.
    Jan 2008
    Central Scotland
    101 Post(s)
    Trim : SRI
    Engine : 2.0 CDTI
    Quote Originally Posted by Aidi View Post
    could that be the reason my gps isnt operating on mine?
    i installed the gps fakra antenna but didnt change the roof aerial over
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    if you need a hand fitting it im free this weekend and only live in wakefield mate
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    It was my first time it only took me 20 mins
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by RBH View Post
    If you have fitted an independant GPS antenna then there should be no need to touch your existing radio aerial. The three base types merely accomodate for the requirements of their fitted headunit - radio only/radio DAB/radio and GPS.
    If you're getting no GPS signal to a CD70 Navi you either know to working fine or have no reason to think isn't working fine, I would be tempted to initially check you have your alternate GPS antenna positioned well and plugged into the correct port (BLUE) on the headunit.
  1. Fitting a sub to cd70
    By Keith Fusco in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2012, 15:03
  2. CD70 fitting
    By leonvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 23:54
  3. Help fitting the CD70
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2010, 11:09
  4. how long should the cd70 update take?
    By Advocate in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2009, 19:12
  5. CD70 fitting help!!!!!!!!
    By m3ath3ad in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2009, 21:22
how do reset gps signal on cd70 navi
cd70 navi no gps
