Thread: poor starting when warm
    alicante
    Default poor starting when warm
    I have owned this vectra from new ( 1.9 diesel 120bhp ) it is now 4 years old with 39000 miles on the clock. The car has always run perfect. It recently had its 4 year service and they changed the fuel filter. Since getting the car back, it is poor on starting when the car has been used, but this never happens first thing in the morning.
    The garage has said its nothing they have done and cannot find anything wrong, but today the car took 8 times to start it, but it runs perfect once started
    Can anyone please help?
    Regular Member tosh23's Avatar
    HULL
    Im thinking air lock in the fuel pressure side of things, maybe air lock in between the fuel filter and the injection rail
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    If it's just since you got it back, I'd be back to the dealer demanding they sort it. They've obviously knocked something. Air lock in fuel system sounds unlikely as it would normally clear once started and not return.
    Maybe leave the car with them a few hours so they can replicate the problem?
    Check connection to coolant temp sensor and EGR
    HULL
    Nov 2010
    East Midlands
    Trim : design
    Are you sure the large sealing 'o' ring is properly seated in the filter housing and the screw top is tight, and the two fuel pipes are sealing correctly. Sounds like air being drawn back into the system when the engine is switched off.
    Northern Ireland
    Ive been having a very similar problem. car has done it since i had it. must look and c if the guy serviced it before i bought it. ive been pulling.my hair out ttying to find the problem.
    Northern Ireland
  1. Warm starting problem
    By sheddy in forum Engine & Drivetrain
    Last Post: 7th January 2013, 22:27
  2. 2.0/2.2 Dti poor starting from warm
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2012, 19:14
  3. warm starting issues
    By supersteve_75 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th June 2012, 17:55
  4. Bad starting From Warm
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 19:06
  5. DTi starting issue when warm (not hot or cold)
    By James24 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 20:28
