Thread: What Gearbox do I have, or how can I find out?
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Default What Gearbox do I have, or how can I find out?
    Wanting to do a G/B Oil change due to the car covering 52K, and the notchy 1st to 2nd change.
    It's an 06 1.8VVT with a 5 speed Manuel.
    Any Ideas what box I have, also what Fluid do you guys use? I heard of VX filling their boxes with PAS Fluid!!!
    Matt
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    not good news mate, ive also a 1.8vvt '06 manual. we have an F17 gearbox, and to change the oil, you gotta pop a driveshaft out, theres no plug!! I looked into doin an oil change myself but gave up. hth
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    As above, F17, and no easy way to do an oil change in these. Remove the Differential Pan to drain and remove the reverse light switch to refill. Think the revised replacement fluid amount was 1.8lt.
    Feb 2012
    Calne UK
    A Drive shaft? WTF?
    What sort of "engineer" thought that up???
    Looks like a weekends work for me then!
    Might be worth drilling a drain hole with and making a plug for it...
    I mean Christ on a bike... a drive shaft out!
    Thanks for the info guys.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by VVT-i-MATT View Post
    A Drive shaft? WTF?
    Unless you remove the reversing light switch and get one of these http://www.ebay.co.uk/itm/OIL-FLUID-...ht_1290wt_1037 and suck it out - might be quicker and easier
    Feb 2012
    Calne UK
    Quote Originally Posted by alcutler View Post
    That sir, is a good idea..... Didn't even know these existed..
    Good way to measure the amount of oil thats come out too... I like it. They sell these at Machine Mart too... Going to have to give these a go I think.
    Matt
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Matt
    That one listed on Fleabay is a bit cheap and nasty - but would probably do the job. You can get electric ones that some garages use all the time to change engine oil rather than mess with drain plugs. Good luck with it.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
was do a vvt gearbox look lik
