Thread: passenger HID not working intermittently
    argyll, scotland
    Default passenger HID not working intermittently
    Just noticed a problem last night my passenger side HID had stopped working so i changed it for a spare one i had in the shed and it worked fine, let the car run and notice it flick off checked all connectons they were fine so disconnected the main and re-connected and it comes on but only stays on for about a minute at max.
    This is only the passenger the drivers side is fine, i do not have the cancellers fitted as i didnt need them and i have had these HID in for nearly 2 years.
    I did recently replace the passenger headlight with a second hand one after a wee bump but that was on sunday and i have been using them since then.
    Any ideas whats up ? do i try the cancellers out ??
    cheers
    argyll, scotland
    Swapped the ballasts over and the drivers one isnt working, tried the cancellers and nothing so i guess its a faulty ballast
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I had a similar problem..eventualy turned out to be the connectors. Ended up cutting all the connectors off and replacing thenm with crimp on connectors covering them with insulation tape..worked for me.
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Quote Originally Posted by nikroc View Post
    I had the same problem the connections inside the connectors become loose, I just adjusted the pins inside to improve connection, They are prone to water inside also, so give them a blast with WD40.
    argyll, scotland
    bought a new ballast and all sorted now
  1. Passenger Window switch not working
    By akeem in forum Bodywork & Interior
    Last Post: 29th December 2012, 05:37
  2. Replies: 23
    Last Post: 17th November 2012, 23:49
  3. front passenger fog light not working
    By familyguy83 in forum Troubleshooting
    Last Post: 12th March 2012, 22:39
  4. Passenger Side Light not Working
    By Envy in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 21:37
  5. Passenger Side Light Not Working
    By PORKBALLS29 in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2011, 17:49
hid on vectra only 1 side working
