Thread: New head unit ignition activated?
    Regular Member smiler1982's Avatar
    Nov 2011
    Northampton
    Default New head unit ignition activated?
    I have received my new stereo (JVC KD-R521) and installed it however it does not turn on or off with the ignition. I know this is because the standard HU was switched by CANBUS and that i should connect up to the ciggy lighter (12v).
    I have swapped the red & yellow wires until the unit worked. The question is on the wiring harness (CT20VX03 Wiring Harness & Aerial Adapter) there are two loose cables. I presume one of these should be connected to the ciggy lighter?
    Also do i need a male aerial connector?
    Thanks in advance for your help!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I think it's the red power wire that provides constant power and the yellow with the key. The constant gets its feed from the HU loom and the ignition from the cig lighter, if that doesnt work then just swap the red and yellow around at the fuse holders.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    What rush said connect tue yellow to the black one on the lighter
    Nov 2011
    Northampton
    The two loose cables are orange and red....I think so anyway as i am slightly colour blind. The other loose cable is a shorter and thicker yellow one with a connector on it, is this the one i wire to the ciggy lighter?
    Thanks again!
    Nov 2011
    Northampton
    Thanks again!
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    http://www.jvcmobile.co.uk/documents...stallation.pdf
    RED is power to ignition,
    YELLOW is direct power to battery
    BLACK is ground
    Orange (optional) is for dimmer switch
    Blue goes to amp and subs if you have them
    Nov 2011
    Northampton
    Thanks Rushy.
    It may be a coincidence but now my cruise control doesnt work!!!!
    This has nothing to do with the stereo loom/canbus does it???
    Blantyre
    No it doesnt the CC is just crap on the vectra , there are many posts mate on how to clean/remove , and there are a few posts under my name
  1. New Head Unit
    By Exclusive BV in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2012, 00:22
  2. Head unit
    By craigmerry in forum Parts for sale
    Last Post: 6th April 2008, 16:37
  3. head unit
    By fixerman in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2007, 21:47
  4. Ignition supply for head unit
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2006, 16:11
