Thread: Coil Spring Compressor
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    Default Coil Spring Compressor
    Hi Guys,
    Planing on getting a new suspension setup soon but realised I've lost my old compressors and I'm looking for recommendations for getting a new set.
    My old ones were really good, I acquired them from the GF's Grandad since he had loads of tools from when he had his own Garage and at 86 he's not really up for swapping out suspension parts any more. Mind you he'll still get his hands dirty, he's just not so good at rolling about under the car anymore. Impressive really!
    Anyway, I'm digressing... What have you guys got? What's good and what's to be avoided?
    South east
    I've got these Laser ones, they work well:
    http://www.lasertools.co.uk/item.aspx?cat=777&item=1480
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I have these and can't fault them, been used loads of times
    http://www.ebay.co.uk/itm/Sealey-Coi...item1e63dea64a
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Never used them on the Vectra and I have done quite a few. Point the shock away from you while you undo the top nut and you will find there is very little compression. This works fine if you are refitting lowered springs because you only have to push this down a bit to get the nut back on. If you are refitting the same springs you might need to use compressors then.
    WARNING you do it this way at your own risk!
    Jun 2011
    Cheers for the recommendations guys.
    merikiito - I'm regularly a clumsy oaf so terrified of attempting it without the compressors, with my luck, I'd have my arm off! Did you see the mess I made of my last service?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by BYGino View Post
    I originally saw a someone take the spring off without the compressers trying to show off and expecting everything to go flying but it didn't. He was warned before hand by me that it could be very dangerous and in the end we both looked idiots as nothing really happened (It was a Vectra c shock). I would only do this on standard shocks and springs and only on the Vectra C.
    WARNING Do not attempt this on any other car
    SECOND WARNING Do this at your own risk
    By the sounds of it you need to stick to the compressors, shame you were not nearer as u could have borrowed the set I have
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Can get some decent lazer ones from halfrauds for about 20 quid
  1. Coil Spring Again
    By Wolfie01 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2012, 22:30
  2. Coil spring
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 7th May 2012, 18:07
  3. Broken coil spring
    By Dobs in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2011, 07:24
  4. Spring Compressor Calmps...
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 22nd January 2010, 10:27
  5. spring compressor
    By dominic32 in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2009, 21:51
coil spring compressor vauxhall vectra 2007
vectra c spring compressors
vectra coul spring compressor
