Results 1 to 10 of 28
Thread: no security code for cd70
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default no security code for cd70
    Sorry about this guys your probably getting sick and tired of my questions about this but the thing is i dont have the security code to enable my factory fit bluetooth so will this help what you think here is the link
    http://diagnostics.org.uk/shop/index...&products_id=7
    scottish region
    did u get the cd70 with a paired screen
    8 Post(s)
    Did the CD70 come as standard with your car?
    If so, then ask Vauxhall for the Car Pass that contains all the necessary codes.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    No it didnt come as standard i got it paired of the bay but with no codes it works fine but i cant use my built in uhp now
    May 2011
    bispham, blackpool
    Quote Originally Posted by pipamish View Post
    im sure its cheaper just to go and get it from vauxhall if its just the radio code you need
    if you tell them its not factory they will take serial number from the back of the cd70 and give you a code from that if it has one
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Can't you get any details from the original seller?
    As per your previous thread you will need to approach Vauxhall or get the code extracted from the unit. I would personally get the code from Vauxhall (if you can supply the correct details) however if you can't I would get the code extracted from the display not the CD70. As they are paired the same code will work on both the display and CD70.
    Duplicate post
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Yeah i think this is best so ill whip out the cd70 and put back in my cd40 for the time being
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I have sorted it i went and registered on this site i posted the link up for and it can be done what he needs to do is reset my bluetooth from my cdc40 opera and reset my cdc70 navi then pair it all up together to my car under my own security code for it all to work all this for £60
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    thats a result fella
  1. Replies: 6
    Last Post: 3rd March 2013, 17:36
  2. Where can I get my car security code?
    Last Post: 28th February 2012, 02:22
  3. Security code
    By stevie16v in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 03:38
  4. Security code
    By edgaras in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2010, 03:29
  5. Security code on CD70 Navi
    By Largespanners in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2009, 16:53
cd70 navi security code
