Thread: front driving/fogs
    Regular Member LeylandRick's Avatar
    Jan 2012
    Lancashire
    Default front driving/fogs
    hi there. My 54 plate siggy elegance does not have any driving lamps, just the silver blanks. are these easy to fit (for a noob) any pointers to where i can get some, googlin seems to be giving me everything from porn to the weather..lololo
    or maybe its the Shiraz !!!!
    11 Post(s)
    Driving lamps?
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Fog lights.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by DeeBe View Post
    Fog lights.
    driving lamps/ day lights, have different lenses and bulbs to fog lights, should only use fog lights in fog or falling snow, there is a bobby around here, if he sees you with fogs on when they shouldnt be, 40 quid fine (misuse of fog lamps)
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Easy to fit, yes, easy to get working as a factory set up, no. You'll need a Pair of lamps, obviously, a loom, a light switch, maybe another under bonnet fusebox(being a signum the fuse box may be compatible), Foglight Surrounds, a tech2 session to activate them and a bit of luck.
    http://www.ebay.co.uk/itm/VAUXHALL-S...ht_1953wt_1199
    http://www.ebay.co.uk/itm/VAUXHALL-V...7#ht_500wt_715
    http://www.ebay.co.uk/itm/VAUXHALL-V...6#ht_500wt_715
    I have been in the process of upgrading to factory fitted front fogs for around a year or so. No luck so far. At the moment I have mine working the old fashioned way with a small switch on the dashboard and a relay in the battery box.
    11 Post(s)
    Quote Originally Posted by CLOMP View Post
    Please don't use them when it is snowing. The glare and reflection from the snow on the ground is worse than when the futile fog light idiots use them in the rain.
    They're called fog lights for a reason - ie, to be used in foggy conditions.
    Otherwise they'd be called snow lights, or rain lights, etc.
    Jun 2011
    South Shields
    I know this, I was referring to the fact that the OP was describing his foglights. I've had cars with DRL before.
  1. 06 2.2 sri front fogs
    By 06sri in forum Bodywork & Interior
    Last Post: 18th June 2012, 19:49
  2. Front fogs...
    By mutley in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2010, 13:24
  3. front fogs
    By pmw123 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2008, 00:40
  4. Front fogs
    By fishphone in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2007, 12:56
