Results 1 to 10 of 14
Thread: Cruise control not activating properly
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    122 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Default Cruise control not activating properly
    Hi all as per the title the cruise control on my 2006 1.9cdti 150 is not activating properly.
    if you push the top button to set speed etc nothing happens apart from now and again the light will flash up.
    if you push the lower button the cruise olight will illuminate for a split second but if you tap the button hard with your finger it will engage, however if you hit a bump or even breathe on stalk it cuts out.
    i have tried lifting the clutch pedal and brake with my foot but is no different ! . anybody think it may be the stalk rather than anything else?
    Thanks in advance
    slough
    mine did exactly the same until i re-solderd the throttle body pcb..... all good now. must admit it was the last thing i tried after clutch and brake switches, clutch spring, cruse control switch. throttle pedal.
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Thanks for the prompt reply, i have allways been a petrol man until this one , been browsing the site today for info on a couple of other issues which i have sorted and come acroos a few people saying about resoldering throttle body,
    would you mind telling me exactly what you mean?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    nine times out of ten fella its the contacts on the stalk there is a how 2 on the site that shows you how to remove the stalk and clean the contacts
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Thanks i will have a look for it, i have found the info on resoldering the pcb on throttle body so i will check/clean that at the weekend when i check and clean egr
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by jon1.8sri View Post
    Hi, I appreciate this sounds a bit basic - I was having to press mine 3/4 times before it would operate - I sat in it one day while waiting for the kids to come out of school and kept pressing and releasing the CC rocker switch and it works every time since. I can only assume there was some dirt / corrosion on the contacts in the switch because of the infrequent use and by repeatedly switching it cleaned the contact.
    Ireland
    +1
    Use electrical switch cleaner.
    Gerry
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    having similar problems, its probably the stalk, u will need to dismantal the coverings around the unit. once u have done this you can see where the stalk goes into the unit. from here u can see a grove/ hole on the bottom of the stalk, use a paper clip or something similar to go into the hole which has too be thick enough which presses a clip down which releases the stalk, please note what ever you use make sure its long enough, goes in about a inch or two. the stalk should come out very freely if you have done it right. you will see on the back of it metal contact plates 4 of them, using some imary paper get it back to a shine but dont wear it down too much. the contacts inside the unit are a little trickyer, you can try the stalk at this stage might be ok but u wil have to very gently use a bit of imary paper to clean the contacts inside you will have to be very pacient it is slow be very careful when you do this bit, give that a go see how you get on.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Remove the stalk and give the contacts a clean. Mine was doing the same as yours and all I did was clean the contacts and it now works perfectly.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by hippo View Post
    tried everything then this , all fine now with only the very odd blip.
  1. Climate control not working properly
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 13:28
  2. Cruise control
    Last Post: 18th June 2011, 12:27
  3. De-activating/Re-activating CDC Stereo
    By L11Marc in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2010, 17:20
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Climate control not working properly
    By Aussie in forum Bodywork & Interior
    Last Post: 13th November 2007, 22:49
