Thread: sluggish
    Southampton
    Default sluggish
    little help please guys after reading through the tech help section i cant seem to work out which i have a issue with be it boost pipes or the EGR
    car starts fine,
    had a engine sign with a spanner once but not seen it since only stayed on for about 5 seconds
    i pull up to a roundabout and go to pull away and first gear seems slow but second is sluggish 3rd is not to bad seems to be a issue between 1k and 2.5k revs
    it seems to be lagging between 1k and 2.5k revs
    i have also just had the front flexi joint changed about a week ago if this has anything to do with it
    the engine is a 1.9 cdti 06 plate vectra
    Southampton
    well it would apear t hat gear has nothing to do with it and its really just the rev range
    pulls away fine still in first tho
    but no power between 1k and 3 k
    engine light has come on a few more times now
    normally after ive been driving for about 5 minutes and stays on for 5 minutes then goes out
    Southampton
    exhaust light came on today while on the way to work and only went off when i turned ignition off
    could this be a issue to do with the fact that the flexi pipe at the front was changed ie its to small not letting enough air out the engine ?
    Regular Member mace's Avatar
    Jan 2008
    Wiltshire
    Start by putting some of the bp ultimate diesel or equivalent (shells Vpower) in for a few tanks and see if it makes any difference.
    Southampton
    ok will do is it worth using redex with it?
    Southampton
    had the altornator changed about 2 months ago and seem to remember the engine bay being cleanish
    i popped the bonnet today to check the boost pipes were all ok and couldnt see any real faults or wear and tear
    but i did notice that the engine bay now has a sligh brown tinge to it
    any thoughts?
    Jan 2008
    Wiltshire
    Quote Originally Posted by iokarus View Post
    certainly wouldn't do any harm, personal favourite is millers but my personal feeling is once you can clear the crud out running the premium fuel keeps it clear.
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    What mileage has the car done?
    Try cleaning your EGR and boost sensor. (Check the how to section).
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Mine did this, I took off all of the vacume pipes to the turbo to check them, all seemed ok so put them back then the car worked fine, not quite shure what it was but it seems ok for now.
  1. 07 SRi Sluggish
    By obews in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 20:30
  2. Sluggish again
    By durham4416 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:20
  3. sluggish
    By chrosty in forum Diesel Engine related
    Last Post: 29th December 2010, 23:55
  4. sluggish 1.9 cdt
    By thommo in forum Introduce yourself.
    Last Post: 16th March 2010, 14:57
  5. Car feels a bit sluggish
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 23rd March 2009, 09:28
