Thread: recirculation problems
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Default recirculation problems
    on my 06 sri direct I cannot tell if my air recirculation works and the light on the button does not come on, the fan works on all settings and the direction control works when i change it from scrren to all the other settings and the temperature works as well, any ideas
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Simple to check.
    Point the air to the face vents and put the blower on full.
    Press the re-circ button and the airflow and noise from the fan should change.
    If it doesn't, or you can hear clicking noises from behind the glovebox it means the re-circ solenoid has failed. This is fairly common and the new part is about £60 from VX.
    It is on the side of the blower motor assembly and operate a flap above the blower, either drawing air in from the footwell area or through the pollen filter.
    BTW, re-circ doesn;t operate if the air is set all up the windscreen.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Simple to check.
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    just checked, have the dreaded click, cheers for you help,
  1. Recirculation button
    By stevie16v in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2013, 11:30
  2. recirculation air vent
    By melvyn8181 in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2011, 23:36
  3. Air Recirculation not working.....
    By big nath in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2010, 16:47
