Thread: CD70 won't eject sat-nav disc
    Oct 2009
    Aberdeenshire
    Default CD70 won't eject sat-nav disc
    Hi folks,
    I am having problems with my CD70, it won't eject the disc that is in it tried pressing the eject button down and wiggling another disc in it which has not worked so far, I have only had the Vectra just over a week, and i just though the car didn't have a disc at all so didn't worry that much.
    The car is going to the garage i got it from for a few jobs that they should have sorted out before selling it, so will mention it to them but doubt its going to do anything, its not anything that i think covered by the warranty or sale of goods dispite the fact i was told that everything was fine with the car.
    cheers for any idea,
    mark
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    i take it the navi does not work at all , or is it just the fact the disc wont eject ?
    Regular Member LeylandRick's Avatar
    Jan 2012
    Lancashire
    Hi mate. I had the same issue after i had tried to update the firmware. The disc would not eject at all. Pull out the unit and unplug the connectors at the back. Give it 5 mins, plug it back in and as it powers up, hit the eject disc whilst it is spinning up.
    Rick
    Oct 2009
    Aberdeenshire
    yeah, the navi don't work at all, i dont have keys to get the unit out, so will try pulling the fuse, do i need my radio code for this?
    Vectra-sport Admin
    Vehicle : VXD
    sounds like the same problem i had with mine the navi just gave up and died i went to vxl and they dont repair them i ended up buying a working unit off the bay and had it re-programmed to the car with tech 2 . To remove the disk i went armed with a couple of torque drives and a set of radio keys ( £3 posted from ebay ) took the unit apart and swapped the drive wire over with the cd then plugged it back in and ejected the disc that way around .
    As you have only just bought the car i would fetch it back and tell them to sort it
    Jan 2012
    Lancashire
    yes, just insert four thin drivers, or long nails in and then gently ease out the unit.... i did..
    also i didnt need the code when i did it this way ( disconnect the power loom from back of unit whils no keys in ignition), but i dont suppose that will be the same for you.
    Jan 2012
    Lancashire
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You don't need a code for the cd70 as it's full canbus
  1. What cd70 nav disc is best?
    By Craig1985 in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2012, 21:51
  2. CD70 disc
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2011, 23:20
  3. cd70 disc
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 21:17
vauxhall vectra cd70 navi wont eject cd
cd70 navigation disk eject problems
cd70 navi disc tray not working
cd 70 disk problem
Cd70 wont eject
nav cd 70 wont reject
cd will not eject on vauxhall omega
cd 70 navi disc wont eject
