Thread: 55 plate Signum 1.8 (facelift) loosing coolant somewhere
    New Member Jonathan & Ali's Avatar
    Keith, Scotland
    confused 55 plate Signum 1.8 (facelift) loosing coolant somewhere
    I hope someone can help me.
    I have recently over the past few months i have been getting the collant light coming on the dash saying it is low. After checking shure enough its about an inch under the cold mark, so i top it up. About 2 - 4 weeks later it comes on again so i do the same again. Whilst this has been happening i have noticed that my exhaust emissions light has been on now and again but goes off after a while. Engine to my knowledge still has original water pump and belts but i cant be 100% shure about this. I look forward to any help you guys and gals can give. I just hope its not gonna be the head gasket.
    Regards
    Jonathan
    Aug 2010
    Leeds
    You need a coolant pressure test to find the leak which maybe a simple pin hole in a hose or radiator which under pressure leaks.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Take the expansion tank off and have a look at the back for a hairline crack. Very common fault and only £20ish from VX to replace. You can also do the Pedal Test to see what codes lie behind the EML light.
    Keith, Scotland
    ok cheers for the tips. will do this at the weekend as wife has the car all week. The code for the eml is 0170 exhaust emissions lean or something to that effect, have been advised to try a new mass air flow meter for that.
  1. 2.8 Veccy loosing coolant!
    By the_rocker in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2012, 14:17
  2. Loosing Coolant
    By Coupe2T in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 10:03
  3. Loosing coolant & foaming
    By si_hoss in forum Engine & Drivetrain
    Last Post: 27th January 2012, 14:12
  4. Loosing coolant on my 3.0DTi
    By Maurice in forum Engine & Drivetrain
    Last Post: 16th September 2010, 22:06
  5. loosing coolant oh oh
    By toast in forum Engine & Drivetrain
    Last Post: 21st June 2010, 22:03
