Thread: 1.9 cdti 150 Fault: P1109 B SENSOR
    Wolverhampton
    Default 1.9 cdti 150 Fault: P1109 B SENSOR
    My car is registering fault P1109 - B SENSOR INTERMITTENT. I presume it's a dodgey boost sensor? I've lost all power. Hardly moves above 2k rpm. I've taken the sensor off the manifold and cleaned. Still getting the problem. Quick restart and did 40 miles on the m6 sound but after another restart had this same problem. Does it need replacing? Vx want 83 quid for a new one.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Take the part number and ring around. Try vauxhallworldparts.com for starters.
    Wolverhampton
    Would you say that is what needs to happen before I buy a new one though?
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    It does sound reasonable. I you can find someone nearby, it is easy to swap them over to see if the fault is rectified.
    Wolverhampton
    I'm trying to find someone. Is imagine It's not the vacuum pipes or intercooler because it is intermittent.
  1. Swirl actuator fault P1109
    By JENK9988 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2011, 17:47
  2. Fault Code P1109
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2010, 20:53
  3. P1109 fault code after alternator replacment
    By knfruitbat in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2010, 21:05
  4. Fault Code P1109
    By SSM in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 11:56
  5. P1109 fault code
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2009, 17:35
p1109 opel vectra c
p1109 1.9
p1109 vectra c
vectra 1.9 p1109
p1109 zafira b
Opel DTC P1109-0F
Opel P1109
Opel DTC P1109-08
