Results 1 to 10 of 15
Thread: Knackered my EGR bolt
    Regular Member toughmat's Avatar
    Home Rhondda , Work in Cwmbran
    Angry Knackered my EGR bolt
    Was taking out my egr valve the other day and the 2 bolts under neath the valve was so tight i managed to round one of the bolts of and i need it removed to finish the job.
    How much will it cost to take to a garage roughly??
    Any pointers to help my to remove this bolt??
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Not had to do this my self so not sure of the positioning of the bolts.. But used to work on the spanners first point of call for me would be try to hammer next size down socket onto bolt head.. If that fails would file a flat on the top and bottom and try to remove with set of vice grips.... Last chance for me would be to grind head off bolt remove egr and wind rest of bolt out with a stud extractor.. Hope this helps.
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Your profile says you have the 120. On my 120 the bolts are allen bolts.
    they are allen bolts but ive rounded the allen shape lol
    Jul 2011
    UK
    Year : 06
    Drill it out
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    If it's stands proud of the face I'd mole grip it.
    Otherwise soak it in WD40 overnight then hammer the next size up allen key in and mole grip that.
    Or, as suggested, drill or dremmel the head off.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Plus Gas (FAR better than WD40) and lots of it - and then Irwin bolt removers..
    You can tap them to the outside of the allen bolts an dthey will bite into the metal - be off in seconds
    Engine : 1.9 CDTi
    You can also knock Torx sockets into the damaged hole as that can sometimes give a better grip and remove it.
    Wolverhampton
    Junior hack saw across the centre then use a large flat head screwdriver?
    Regular Member vekky c's Avatar
    Feb 2012
    galway ireland
    have you a hot air gun try if so try that it got me out of a spot last week,can really heat a small spot without burning all around like the gasi cant understand how the allen key spun inside the bolt,not calling you stupid or anything but are you sure it was the proper size allen key cos mine was a very snug fit ?
  1. ECU is knackered
    By dhwigston in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 16:09
  2. My DPF is knackered! Help!
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 6th March 2012, 15:46
  3. Think my key is knackered
    By vectrasri20t in forum Bodywork & Interior
    Last Post: 26th February 2010, 12:01
  4. Im knackered.....
    By PAULMAC77 in forum General Chat
    Last Post: 14th April 2009, 09:51
