Thread: DIY Paint Job Qestion
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default DIY Paint Job Qestion
    Painted my front grill with black gloss spray paint. There are little mist marks on the paint which is preventing it from being really flat.
    Can I rub it down with wet and dry to flatten it but not take any of the shine away for when I put the laquer coat on as I don't want to give it anymore coats of paint.
    If so, what grit and should I do it wet or dry?
    Thanks.
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Just rub it back with some 1200 grit once all flat lacquer it up and will be sound
    Mar 2011
    Wirral
    Will the 1200 be ok with regards to not dulling the paint?
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    It will make it dull down a bit but the lacquer will brighten it back up
    Mar 2011
    Wirral
    Ok thats great cheers mate, up and out tomorrow for some 1200 grit w&d 1 more thing, should I do it wet or dry? Thanks
    Full Member paul.sessions's Avatar
    leighton buzzard
    try 2000 grit dry then wet then lacquer after
    Mar 2011
    Wirral
    Ok thanks for replies
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    When I'm flattimg before lacquer I do it wet not sure if it makes a difference or not
    Mar 2011
    Wirral
    Ok I will do it wet, I trust you both so Im going to go in the middle and get some 1500 grit! Cheers lads
    Full Member Big Sig's Avatar
    Soak the wet and dry before you use it too. Maybe worth adding a little car shampoo as a lube in the water.
  1. Replies: 2
    Last Post: 17th November 2012, 11:24
  2. Where to buy paint from
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2010, 17:45
  3. Quick qestion
    By RN37 VXL in forum Bodywork & Interior
    Last Post: 23rd January 2010, 15:15
  4. Rear brake qestion.
    By Jekyll & Hyde in forum Handling & Braking
    Last Post: 20th December 2009, 15:24
  5. normal spray paint or caliper paint?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 20:59
