Results 1 to 10 of 18
Thread: Pulsing boost prob NOT fixed!
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Pulsing boost prob NOT fixed!
    I recently posted that the pulsing boost im getting under load is fixed, but its returned which is annoying, its on my saab 93 (z19dth) , changed the boost controller which seemed to cure it but not for long, im begining to think its my inlet manifold causing it as i had to fix the swirl rod back on a while ago, it is still on but very loose and ive got gunk and fresh oil on each swirl flap, could it cause the pulsing boost im getting?, ive read a few posts on here with a couple of guys describing same symtoms, did any of you find a cure? Cheers
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    There are two boost controller for this engine - well on the Vectra/Signum anyway. One I believe is if you have the engine with the vacuum reservoir at the back. If you have then if you follow the turbo vacuum pipes from the vacuum pump it will join onto a metal pipe, this will head down the back of the engine. Next to that metal pipe there is another one that follows the exact same path it will join onto the other vacuum pipe.
    The other type of vacuum system misses the vacuum reservoir out completely.
    This is the need for the two different types of boost controller. I know I have the same issue as you and bought the wrong one.
    Insignia VX-Line Nav CDTI 170.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Cheers for the quick reply i have got a vac box at the back of the engine but bypassed after reading i could, ive not noticed or heard of another boost controller on these engines mine is a 2005 , i changed the one under the slam panel at the front with the two vac pipes connected
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by Richard.roberts View Post
    There are definitely two n the Vec as I bought the one for the engine without. I would double check if there are two. If you bought one for an engine without a Vac box it may still cause the problems. I think this is the issue with mine. Albeit I haven't bypassed the vacuum box but if it's there the ECU will be using the boost controller like the vac box is there, and subsequently as the boost controller you have may not be for this engine it may not be working as designed to.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Thanks for that mate il connect the vac box back up and try , and have a look for the other controller , i defo need a new inlet manifold though but gona take me e few weeks to save up, been doing my homework on changing it ,awsome how2's on here. Anyway this pulsing doesnt happen if i accelerate by feathering the throttle in , only when i floor it 3rd or higher!
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Same here mine does the exact same.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Do you know what the other controller looks like?
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    On the Vectra it's a wee black box and there is a cream coloured bit at the end that the vacuum pipes go into - the one from the vacuum pump and the one going to the turbo.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Thats the one ive changed! It was used but it didnt solve my prob
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    How did you know which one was the right one , by the number stamped on it is it? And if so do you know the number for the one with vac box cheers
  1. pulsing boost prob finally fixed!
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 19th February 2012, 23:50
  2. HELP!!! Engine Pulsing and wont go over 4k revs!!
    By sub2199 in forum Engine & Drivetrain
    Last Post: 6th December 2010, 10:26
  3. Boost sensor prob
    By wolvesdaz in forum Engine & Drivetrain
    Last Post: 7th October 2010, 20:53
  4. Pulsing boost
    By Gazza36 in forum Engine & Drivetrain
    Last Post: 29th April 2010, 17:58
  5. LED Flashing / pulsing
    Last Post: 30th October 2009, 22:56
