Thread: Anyone know how to remove front seat ( vectra c)??
    essex
    Default Anyone know how to remove front seat ( vectra c)??
    Having a right mare guys trying to remove the front passenger seat from my 2004 vectra c.. The adjuster mechanism is busted so i cant move the seat forward/ backwards so i wanted to remove the seat to sort it but no matter how many 13mm bolts i remove i cant get it to budge?? Cant see any thing else other than 2 large star keys at the rear of the seat // I ve removed everything i can see from the front but it wont lift yet?? Doin my nut in right now lol
    Any tips would be most helpfull right now thanxs
    Jul 2010
    Warrington / Liverpool
    Its those two torx bolts at the back, take them out then slide the seat and tilt it forwards... Don't think there is any 13mm bolts to undo
    essex
    cheers for the fast reply buddy, should of guessed it was the only 2 i didnt remove lol...
    essex
    Great seems them 2 only do 2 turns then jam up! Cant get them out past that. Dont know how im ganna get them out now, just took half the skin of my knuckles when the torque slipped out! F**k
    Nottinghamshire
    Isn't the first thing to do to disconnect the battery negative terminal and then wait 10 minutes for the airbag system to discharge before disconnecting the wiring multiplug under the seat?
    essex
    didnt think of that one tbh, will do that once ive found out how to remove them daft tight bolts from the seat! seems the torque tread in the bolts is starting to chew up were there so tight.. **** knows why they use them style bolts and out them in such an akward possition?? Really hard to get the right angle on them to get the right grip to turn them when there tight! Maybe if i do get the bolts out ok i might be able to sort the mechanism underneath out without fully removing the seat!! I can see the levers that push down the pins to allow the seat to move are all bent up on one side! No idea how that has happened?? The seat has never worked since i bought it last yr! One of many daft issues with the car right now.
    Nottinghamshire
    Good luck with the bolts.
    If you have a factory alarm, you have to disconnect the battery within 10 (I think) seconds of switching OFF the ignition (from position II) otherwise the alarm will sound using it's built-in battery for power.
    Regular Member suj786's Avatar
    glasgow
    I knew there was a HOW 2 on this somewhere
    http://www.vectra-c.com/forum/showthread.php?t=15095
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    dont forget to un clip the plug under the seat before removal,you dont
    have to disconnect the battery as long as you keep the ignition off
    then remove them 2 bolts at end of the rail then your free to remove the
    seat.
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    Quote Originally Posted by suj786 View Post
    really easy, but take your time............
  1. remove tissue from the front seat
    By msqualo in forum Bodywork & Interior
    Last Post: 5th March 2012, 10:14
  2. How to remove Vectra 2008 front grill
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 17:25
  3. Replies: 11
    Last Post: 15th June 2010, 17:24
  4. Vectra 03 front passenger seat - Did they ever come with handles
    By Schui1024 in forum Bodywork & Interior
    Last Post: 15th June 2009, 22:56
  5. How do you remove Vectra rear seat back??
    By smokie in forum Bodywork & Interior
    Last Post: 9th January 2009, 23:51
how do i take the front seats out of my vectra c
How do you get the front seats out of the Vauxhall vectra 2003 diesel
How do you get the front seats out of the Vauxhall vetra 2003 deiel
vectra c seat airbag removal site:www.vectra-c.com
vectra seat bolts chewed
front seat bolts for 2004 vectra club
