Results 1 to 10 of 18
Thread: Swirl Bar off Completely
    Regular Member tgarrett's Avatar
    Apr 2009
    Newton Aycliffe
    Exclamation Swirl Bar off Completely
    I just had a butchers at the swirl bar and its off completely, i took off a couple of bits to get to it, tried to put it back on but the plugs must be ******ed.
    I havent had a code or gone into limp mode at all. i was looking at taking the EGR off when i noticed.
    Is a new inlet needed? Why have i not had a code?
    The car runs normal it seems to me but stupidly i never checked it when i got it a couple of months ago so it may have been like this when i bought it.
    Regular Member badback's Avatar
    Runcorn
    My swirl bar was off for about 30K, the smell coming into the cabin was the only difference that I noticed, but after a new manifold it was like a different car. It had lost alot of it's power. It was like it had been remapped, because I have had it remapped since and it seemed similar to the power increase when the new manifold was fitted. The car seemed to run fine before the new manifold, no symptoms other than the smell, but I was fortunate to have the cash for a new manifold so got it done.
    Apr 2009
    Newton Aycliffe
    I havent got any spare cash at the moment so its going to have to wait.
    Im thinking it will be alright for now with things the way they are.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    I put my swirl pot rod back on and wedged it In with a few pieces of foam and 12k later the rod is still on and car still runs fine. There is a how too on here for a cheap fix fella
    Apr 2009
    Newton Aycliffe
    Went out took the bar out and had a quick look.
    The plugs are pretty knackered. I put it back on all the nipples which was an effort!
    Turned it over and the 3rd pot has popped straight out leaving the others in the open position.
    This put the car in limp mode so I had to take the bar back off and move the others all to the left.
    The car is now back to normal. No limp mode or codes but it will still need sorting.
    Apr 2009
    Newton Aycliffe
    Wolverhampton
    Lost mine about 20k ago. Not had any problems. Runs as smooth if not better.
    You can cause more problems messing I think. Also had limp mode when i tried to bodge it back on so ended up leaving it without.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Glue open valves 1,2,4. Leave 3 to move with the motor. Mines been like this for 10k miles now and runs like new
    West
    Quote Originally Posted by tony-1977 View Post
    Mine runs like a dream too
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    It is there to cause the air to rotate around the cylinder at low reves to improve the mixing of the fuel in the air charge, giving a more complete burn. If the valves are not leaking and they are over to the left in the open possition, I would glue them there and leave it be. You might notice a very small drop in economy and performance below 2000 rpm but they never are impressive down there anyway. It won't harm the car and isn't worth a grand to improve emissions slightly :/
  1. Completely stumped
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2010, 00:08
  2. EGR Valve now completely blanked off...
    By Dan_BlackSRi in forum Diesel Engine related
    Last Post: 27th October 2010, 07:36
  3. Who's completely potty?
    By RhayaderSax in forum Comedy & Humour
    Last Post: 11th September 2008, 13:03
  4. Completely random - At the dentists
    By Boy Lard in forum The 'Off Topic' room
    Last Post: 8th July 2008, 09:32
  5. completely pointless spoiler...........
    By merikiito in forum The 'Off Topic' room
    Last Post: 22nd February 2008, 18:03
