Thread: Alloy Wheel Cleaner
    Regular Member dazmufc's Avatar
    Aug 2011
    Birmingham(Oldbury)
    Vehicle : Vectra C Estate
    Trim : SRI
    Engine : Z22YH
    Mileage : 94,000
    Default Alloy Wheel Cleaner
    Basically guys my rear brake was grinding metal to metal which has left a lot of metal dust welded to my alloy, i haven't washed the car for months , hence the word "welded". Anyone got any ideas what i can use to get this crap off with, all Ive tried is just some cheap alloy cleaner i had in the shed which is usually OK for getting of brake dust, but wont budge the metal dust at all.
    Sounds more like it is the heat of the brake material that has been the issue
    Start with Tesco Alloy Wheel Cleaner (buy two bottles)
    Spray about half of one of the bottles on and leave for 10 minutes
    Clean off with a jet wash (spray only)
    Repeat the above
    Compare
    Now, with the second bottle repeat as above but leave for 5 minutes, then use an alloy wheel brush to loosen the brake material
    Repeat the above
    Compare
    If the material is indeed burnt brake pad and disc material then it is likely to have chemically bonded to the alloy wheel and when comparing each stage above you will notice little or no difference
    The best method now is to remove the wheel and jet wash
    If there is no change, then it needs chemical treatment to remove the melted brake material
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Iron X is going to be the best product here I think.
    Aug 2011
    Birmingham(Oldbury)
    Trim : SRI
    Engine : Z22YH
    Mileage : 94,000
    Thanks guys,
    Its going to have to be the chemical treatment to shift this its proper bonded to the wheel.
    DasArab, where can i pick up some Iron X ?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Any of the good detailing companies will stock it, or a comparably product. No doubt you will be able to pick it up off ebay too.
    Aug 2011
    Birmingham(Oldbury)
    Trim : SRI
    Engine : Z22YH
    Mileage : 94,000
    Will my local Halfords stock it, or something similar ?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Different kind but does the same.
    http://www.autobritedirect.co.uk/ind...n-remover.html
    Aug 2011
    Birmingham(Oldbury)
    Trim : SRI
    Engine : Z22YH
    Mileage : 94,000
    Ok mate, and cheers for the links will order some today
  1. Which Alloy Wheel Cleaner.....
    By mpc in forum Detailing and Car Care Discussion
    Last Post: 29th May 2011, 23:15
  2. Alloy Wheel Cleaner
    By KSD in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 08:46
  3. Alloy Wheel Cleaner????
    Last Post: 5th March 2009, 18:33
  4. Alloy wheel cleaner
    By ANDY W in forum Detailing and Car Care Discussion
    Last Post: 16th December 2008, 21:33
  5. Alloy Wheel Cleaner
    By denzo in forum Detailing and Car Care Discussion
    Last Post: 20th June 2008, 23:49
