Thread: help with nav
    Regular Member vectra sri dan's Avatar
    Oct 2006
    newcastle-under-lyme
    Default help with nav
    my sat nav works fine dose the route and tells you the road you on but for some reason the position map has stoped working and will not show . anyone got any idears ?
    Regular Member muffking's Avatar
    When you say the position map, do you mean that it doesn't tell you when you've moved? as this would relate to the speed sensor once the GPS receiver has picked up your location.
    Oct 2006
    i mean when you put it on to map screen it dose not shoe the map at all but the rest of the nav works fine
    Sounds like the map disc. Mine's an aftermarket Navi that works in the same way, but if there's a mark or some dirt on the disc then it can't read the map properly. Try taking the disc out and giving it a clean, otherwise you'll have to fine someone (or a freindly dealer) with a Vectra that has SatNav to try your disc in.
