Thread: sri v6 cdti turbo?
    Feb 2012
    cleveland
    Default sri v6 cdti turbo?
    how would i no if turbo has gone or going?
    has an oil change last week.had a trip to newcastle and it doesnt feel as quick.
    any ideas? thanks
    What type of oil was used?
    Where does the level sit once the engine is warm (not hot)?
    When the oil was changed, was the oil filter changed as well?
    For the turbo, you should hear it when the revs reach 2000rpm
    A failed turbo will run the engine when it is switched off
    A turbo nearing failure will normally show white smoke on the high revs and on idle can often show blue smoke
    Equally, near failure you will hear it on idle (which you should not normally be able to)
    Feb 2012
    cleveland
    actualy an oil change was done but couldnt get the filter off.didnt have the correct tool. would that make it feel slower tho? 3 mechanics said it would be ok....?
    Feb 2012
    cleveland
    Please refer to original three questions from post 2
    I can't offer any further advice until all of these are answered
    Next set questions after that will be
    How long since last service?
    What does the Service Indicator show?
    How long since the fuel filter was replaced?
  1. v6 cdti turbo gone?
    By broad in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 02:25
  2. Turbo gone cdti
    By challc in forum Engine & Drivetrain
    Last Post: 19th November 2011, 21:56
  3. cdti 150 turbo
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 20:11
  4. turbo lag with my 3.0 sri cdti
    By kie h in forum Engine & Drivetrain
    Last Post: 16th October 2007, 15:20
