Results 1 to 10 of 13
Thread: Quiescent current test?
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    20 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    Question Quiescent current test?
    How can I test whether or not my car has excessive current draw when switched off, locked and parked? My battery has not been able to start the engine twice now - first yesterday and then this morning.
    I put the car on a voltmeter at the local friendly garage near work and it is charging at 14.4-14.5 volts, headlamps on or off - nice and steady. Occasionally, the lights dim or brighten slightly - interior and exterior.
    I am wondering whether or not to chance a new battery (hasn't been changed since I've had the car - 5 1/2 years! ) or whether it might be the alternator has a diode pack that has gone bad and is allowing current to "leak" back from the battery whilst the car is parked.
    Any ideas? I might try leaving the battery disconnected overnight tonight. But I am getting fed up jump starting the Vectra in the mornings!
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Dec 2011
    Seaham
    The obvious method is to disconnect the battery, therefore absolutely no current drain.
    You can check for current drain by disconnecting one battery terminal then place a low powered bulb between the battery terminal and the battery lead. If you have a current drain, the bulb will light up.
    Obviously there will be some power drain to keep the clock going etc, but that will probably not be enough to light up the bulb.
    Engine : 1.9 CDTi
    If you have access to a multi meter you can use that.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    double post - why?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Firstly lock the car, but with the bonnet sensor plunger taped down and the bonnet open. I would measure it by:-
    After a few minutes connect a multi meter between the earth lead and the battery negative post and disconnect the earth lead without disturbing the multi meter leads between earth lead and battery post. This is to stop any effects of fully disconnecting the battery and then connecting the multimeter.
    The meter will read the 'fully powered down' current draw. It should be very low, but I cannot remember what the actual number should be. Clearly there will be some current, as the alarm etc still needs some power.
    If the current draw is higher than about an amp, then start removing fuses / relays in the main box next to the battery until you find the one that puts the current to almost zero. If one does make a big difference, then you know the circuit.
    It may be that your battery is indeed knackered and the 'cold' weather is just making it even worse.
    Engine : 1.9 CDTi
    A sleeping car should be about 0.20 - 0.40 Amps (Ie 20 - 40mA)
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by lee gsi View Post
    0.2 - 0.4 would be 200 - 400 mA
    Which is the typo?
    Engine : 1.9 CDTi
    Sorry should be between 200mA and 500mA
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I was going to guess at 500 mA max, but didn't want to mislead if it was wrong.
    20 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    Thank you very much for your replies, guys. I've just been out and about in the Vectra and it's been fine. However, the engine has not been switched off for more than a couple of hours since I got in from work.
    I shall do your quiescent current test tomorrow, Ste. Thanks for that.
    I'll post my results tomorrow. Not sure when exactly. I'm off to the garage to get my digital multi-meter to take with me to work.
    Paul
  1. Current issues
    By danno91 in forum Engine & Drivetrain
    Last Post: 6th September 2011, 11:22
  2. My current set up...
    By danBoy in forum ICE Gallery
    Last Post: 4th July 2009, 12:26
  3. My current pet hate.....
    By AndrewTi in forum The 'Off Topic' room
    Last Post: 29th August 2008, 09:07
  4. current account
    By lborob17 in forum General Chat
    Last Post: 5th February 2006, 15:09
