Thread: Smokey 1.9cdti
    Jul 2011
    Staffs
    Default Smokey 1.9cdti
    Basically the last few weeks the Signum has been getting 'smokier' when accelerating. Cue last week when the 'spanner' light came on when starting, after a mile or two it went off. This has been happening since.
    Saturday a friend of mine used his Tech2 to diagnose the fault and all that came up was a glow plug error. Would dodgy glow plugs cause an abundance of smoke? If not, what else could it be?
    Thanks in advance!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could possibly be causing the car to overfuel. You have had the code read so get new glow plugs then m8. At least one way or another you will know.
    Regular Member Mopar Man's Avatar
    herts
    If it was glow plugs, the EML light would only come on when cold.
    Jul 2011
    Staffs
    Quote Originally Posted by Mopar Man View Post
    Yeah, it comes on when its cold and just started, but goes off when the engines warm or you restart the engine.
    herts
    Sorry wrong thread
    Jun 2009
    Cheltenham
    My Vectra CDT1 120 got smokier and smokier over a long period and lost powere gradually without me being able to put my finger on why until the Turbo seized, solid.
    Root cause was a split intercooler, it didn't hiss, the split couldn't be seen without rermoving the radiator but with no back pressure the Turbo was over speeding, sucking vast amounts of air through the airflow meter and so the ecu was making the injection pump pump huge amounts of fuel so making black smoke. Finally the turbo seized big time.
    Stupidly enough there was no mention of anything like it on this forum when it happened July 2011 and only came to light when Bayliss changed the intercooler and made the car worse when they failed to diagnose a seized Turbo, absolutely seized solid Turbo, and fitted a new intercooler, and then Trevor Carr of Poulton fitted a second hand turbo I got of Ebay.
    Check the intercooler pipes and if they are ok have the intercooler out for a look see.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    I had a new intercooler about 3 months ago. It was leaking bottom right. I used to get loads of black smoke when I booted it. But I think I sorted it in time turbos fine.
  1. Smokey 1.9CDTI SIGNUM WHEN WARM
    By stuggyzx10 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd October 2010, 20:25
  2. Smokey Vec
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 15:57
  3. Help with smokey van please
    By sberrow in forum The 'Off Topic' room
    Last Post: 31st March 2009, 07:57
  4. Smokey SRi
    By MarkEllo220864 in forum Engine & Drivetrain
    Last Post: 28th March 2009, 23:56
  5. Smokey Sri
    Last Post: 27th March 2009, 11:56
