Thread: Aftermarket HU not holding settings
    May 2008
    Bordon
    Default Aftermarket HU not holding settings
    I've fitted in a JVC HU and used a ISO adapter to get the correct wiring. I've also taken a switched 12v feed from the cigarette lighters black wire. Everything works as I would expect except that the stereo doesn't hold it's settings. This is what I would expect to see if a permanent live wasn't in place. Am I right in thinking it should be as easy as swapping the red and yellow 12v feeds in the stereos loom? The ISO adaptor I brought suggests this might be the case.
    PS the only reason I haven't already tried this is laziness.
    gwent
    Yes swop the wires over that your problem
    May 2008
    Bordon
    Cheers for the swift response, I'll give it a whirl during lunch at work tomorrow.
    May 2008
    Bordon
    All sorted.
    I had swapped the perm live and ignition live wires when i was first fitting the stereo and hadn't swapped them back after taking the ignition live feed from the the cigarette lighter socket.
    May 2008
    Bordon
    All sorted.
  1. Battery not holding charge
    By Froggy in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2013, 15:21
  2. Holding back
    By obews in forum Engine & Drivetrain
    Last Post: 29th December 2012, 10:22
  3. Engine holding back
    By paul4400 in forum Engine & Drivetrain
    Last Post: 6th June 2011, 00:40
  4. Holding gears
    By app in forum Engine & Drivetrain
    Last Post: 3rd June 2008, 10:46
  5. Just holding my hands up
    By Ben H in forum Billing 2006 8/9th July
    Last Post: 2nd July 2006, 14:42
