Results 1 to 10 of 14
Thread: Only running 3 cylinders !
    Regular Member Stan-H-'s Avatar
    Sep 2010
    Middlesbrough
    Default Only running 3 cylinders !
    Hi guys,
    Im new to the forum.
    Ive had a health check done at Vauxhall on my 2006 vectra SRi 1.9 CDTi [150].
    They have said its only running on 3 cylinders, what are my options in terms of further diagnostics?
    Are vauxhall the only choice?
    Are there other garages who offer this service?
    What should be the price to do it? (Vauxhall want £192 just to diagnose the problem !!! )
    Thanks.
    Stan.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    You should have noticed on the running and strating if it was only on 3 cylinders. First thing I'd check if it's correctly diagnosed would be 3rd injector. Usually causes misfires rather than no cylinder. Sounds an expensive health check and yes, other garages will do it for you. Is there a local garage you trust?
    Sep 2010
    Middlesbrough
    Quote Originally Posted by Grumpy1954 View Post
    Yes i did notice it running rough when i bought the car but it was my first diesel so i didnt think much of it. It seems to run fine once warmed up.
    Im useless with engines to be honest .... I'll try a local garage and see what they say...
    Will opcom or Tech 2 not work?
    Engine : 1.9 CDTi
    They will read any codes yes.
    I am also surprised there are no engine management lights on with it running on 3?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    First off what colour are your injector plugs blue or yellow?
    If they are yellow then at the very least injector no.3 needs to be changed to the blue uprated version. The kit can be got from VX and will cost about £12 ish.
    What happens it he wiring and plug breakdown on injector no.3 possibly caused by air flow over that particular injector.
    Its a very common issue and many garages are not aware of it resulting in £100's being spent trying to find the issue. You will also find that some garages are aware of it but will telll you lies and charge you a fortune to solve it.
    This only effects the 1.9 CDTi 150 with yellow injector plugs
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    but my 06 has blue bit on plugs and I still have had to do the 3rd injector mod!
    Sep 2010
    Middlesbrough
    Quote Originally Posted by lee gsi View Post
    Hi Lee,
    The EML does come on when i start the car up, and a cloud of blue smoke out the exhaust.
    Quote Originally Posted by merikiito View Post
    Thanks a lot merikiito, i will check this out in the morning and ring around for garages with Tech2/Opcom available.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Stan-H- View Post
    Are you saying its only running rough when first started from cold - and then runs ok when warmed up - that could well be a glow plug issue - was the engine hot when they did the Health Check - and did they suggest what could be wrong with it? As already said if its misfiring when the engine is warm it could be the 3rd injector electrical connection or an injector issue.
    Engine : 1.9 CDTi
    Get it to another garage and get them to have a look and read the codes to start with.
    Sep 2010
    Middlesbrough
    Hi guys,
    Just to clarify, when i first start up the car (normally after its been stationary for more than 5 hours) it runs rough for the first minute and the EML comes on.
    After a couple of extra minutes (around 3/4) when the engine has been running for a bit the EML goes off and it seems to run absolutely fine. no boost issues or misfires.
    Thanks.
    Stan.
  1. running on three and thre quarter cylinders
    By phieziem in forum Engine & Drivetrain
    Last Post: 28th March 2014, 22:38
  2. 3.2 cylinders where?
    By Yugguy in forum Engine & Drivetrain
    Last Post: 12th December 2012, 15:33
  3. Replies: 3
    Last Post: 7th June 2012, 15:42
  4. Engine running on 3 cylinders on cold start
    By philc1210 in forum Engine & Drivetrain
    Last Post: 16th February 2012, 08:49
  5. Been to VX to sort out why my car is running on 5 cylinders
    Last Post: 23rd September 2007, 10:30
insignia firing on 3 cylinders
vectra 1.9 cdti only running on 2 cylinders
Vectra 1.8 sri sounds like running on 3 cylinders
zafira cdti run on 3 cylinder
vaxhall vectra 2.2 sri 150 engine running on 3 cylinders
vauxhall omega running on three cylinders
vectra c only firing on 3 cylinders
opel zafira 19cdti running on 2 cylinders
what causes vauxhall vectra to run on three cylinders
vauxhall vectra 1.9 running on 3 cylinders
is my vectra c only running 3 cylinders
cylinder 3 rewire z19dth
