Thread: z19dth high consumption
    Regular Member tox's Avatar
    Bucharest
    Trim : C
    Engine : Z19DT
    Default z19dth high consumption
    Hello
    I've experiencing a problem with my z19dth engine since this winter, in the fact that overall consumption compared to the last 3 winters has increased from 10-11 liters at 100km to 15-17 liters at 100 km which is unacceptable
    No fault codes present, but i noticed some weird readings using OPCOM:
    The difference from the ECU pressure command,. the ECU commands lets say 150 kPa boost and the turbo responds wtih 120 kPa, almost everytime there is a difference about 20-15 kPa.
    Also, i noticed a difference from the calculated air flow in the MAF, almost everytime the calculated air flow is less with 5kg/h air than the airflow which the MAF reads
    If you need, i can post the real time record with measurings from OPCOM
    Also, the car doesn't feel much alive like it used to be.
    Thank you
    Regular Member tosh23's Avatar
    HULL
    My car is a thirsty beast, 33mpg at moment...1.9 cdti 120. 2007
    Ive been looking at "other symptoms" and came across this...
    http://www.vectra-c.com/forum/showthread.php?t=156342
    It might help......Tosh
    Bucharest
    Trim : C
    Engine : Z19DT
    THank you, i'll check the temp sensor The thing is, at the gauge it shows ok, engine seems around 85 degrees C when normal condition even at -20 gr C (surely, it will go at 80-85 C after 30 mins of driving ) )
    AFAIK, when i had a Calibra, there were 2 sensors, one for the ECU to know the engine tmp and one for the gauge. Maybe this sensor is 2 in 1 sensor, one for ECU and one for gauge. maybe the ecu one reports fake...
    HULL
    Your gauge works fine, it might be the temp sensor to the ecu so that you are running on choke. Vauxhall will be getting my new sensor on Thursday so I will report back..
  1. Help with High Pressure Pump Z19DTH
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2011, 20:59
  2. high oil consumption
    By bombai in forum Engine & Drivetrain
    Last Post: 15th February 2011, 23:14
  3. Powerloss on high speeds (z19dth)
    By genesisfm in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 21:57
  4. high consumption of diesel ?????
    By martinka1702 in forum Engine & Drivetrain
    Last Post: 16th February 2009, 11:31
  5. oil consumption too high???
    By Nickzx6r in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 21:19
vectra c z19dth consumption
z1.9dth high pressure pump www.vectra-c.com
