Results 1 to 10 of 14
Thread: 1.8VVT Oil Light
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Default 1.8VVT Oil Light
    Hi Guys,
    I've done a search for this and I didn't really find much of any help.Got the car a few weeks back and checked the oil. She was due a change, it was discolored but nothing major.
    I gave it a new filter and 5w30 Magnatec Yesterday, and now the oil light stays on for 4-5 seconds after I start the engine?
    Any thoughts on this, is it normal, I don't recall this problem before I touched it. Oil change went to plan, there are no odd noises from the engine, and everything "seems" normal?
    The Oil is still clear and up to the correct level..... any thoughts?
    Matt
    Did you use a genuine filter, or el'cheapo?
    Feb 2012
    Calne UK
    El Cheapo from Halfords.... do you think this is the cause?
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    i used a partco filter. my light stayed on for a while, i topped it up and it went off, same engine btw.
    Feb 2012
    Calne UK
    Might it be that the filter needs to "soak up" some oil for it to work corrrectly?
    Oddly though it doesn't happen when the engine is warm. If I restart after filling up with fuel, the oil light goes out straight away???
    Some filters have a one way valve to prevent it from draining down when the engine is off.
    Not sure if that applies to yours, but the reason for the oil light staying on is maybe the filter has drained down and the light won't go off until the oil pressure has refilled it again.
    Or maybe the filter you've bought is faulty and the valve isn't working correctly.
    Feb 2012
    Calne UK
    A Valve you say?
    Mine didn't have a valve, just the rubber o ring and the cartridge.... I will check the filter again tonight. I will go and get a VX Genuine of too on th way home. Is it going to do any harm in the short term? I mean she runs smooth, and there are no weird noises... Will it BE while I drive to VX to get a new one? Worried now!
    Oct 2007
    Shropshire
    First I will reassure you that mine does stay on for a few seconds, but not 5. I have a lower pressure oil switch you could fit which makes it instant, but there is no need really as the pressure stays the same just the light goes out at a different point....
    Second I would say that it is normally worth buying the genuine filters. There are a few variations of filters that can look the same but can be different.... Often the there is very little price difference or it may be cheaper to get a genuine filter!!! My last one was £5.08 inc Vat so they don't break the bank...
    Finally I will say from experience (my first 1.8 had problems and blew at 33k!!) that even through vauxhall recomend a 0w30 or 5w30 grade oil, it is much better on 10w40 full synthetic. The oil light goes out faster and the oil temperature is cooler... (The vvt's do get very hot oil, hence the lack of an undertray!!) I normally like to put the thinner oil in motors, and put 30 grade stuff in cars that say they need a 40. However on the vvt, the thicker oil does seem to be better even if vauxhall say otherwise!!!
    Also I take no responsibly if you put different oils in, just offering my experience. What you do is up to you!
    Oct 2007
    Shropshire
    Double post...
    Apr 2011
    Southport
    Quote Originally Posted by mucklestone View Post
    Would you still use 10w40 fully synth on a high miler? ive got 107k on clock, and using 5w30 fully synth.
  1. Oil light 1.8vvt
    By PHILPOT in forum Engine & Drivetrain
    Last Post: 6th May 2012, 08:38
  2. 1.8vvt - what does the vvt bit do?
    By GoldenWonder in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2011, 16:09
  3. 1.8vvt
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2011, 11:48
  4. Engine Management Light 1.8VVT
    By philroberts in forum Engine & Drivetrain
    Last Post: 16th August 2011, 21:21
  5. 1.8vvt
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2007, 11:54
vectra c 1.8 vvt oil grade
