Thread: exhaust help please ?
    Regular Member nath-lav's Avatar
    Mar 2011
    newcastle upon tyne
    Default exhaust help please ?
    how do you get a diesel's exhaust to sound loud ? i heard a mondeo st diesel go past and sounded load as ? any help is much appreciated
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    No back boxes, just tail pipe, its quite a common mod.
    Mar 2011
    newcastle upon tyne
    is that including getting rid of the cat ? and how much would this cost about if you no ?
    Vehicle : SRi
    Mileage : 137000
    There are many CDTi owner on here who have de catted and taken there back boxes off. Saying that, the MOT laws as of this year have changed in respect of that so you would have to look at the legality of that now, I know de catting on CDTi's is no longer allowed but not sure on taking the back boxes off.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No reason a diesel can't be decatted as they are not subject to a full emmisions test like a petrol
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    You are not allowed to remove a CAT from a vehicle that had one fitted as standard now though, it is not an emissions test but an inspection pick up.
    As for the exhaust, just remove the back box and try different sized and shaped tips until you get the noise you want. If you have a pipe cut at a right angle to its length it will allow for best resonance. Get an exhaust place to make you some 45-90% bends to clamp onto the end of the exhaust where you removed the silencer with different amounts of pipe flaring. Then you can clamp them on and drive around to see how they sound. If you are not getting enough noise, you might need to remove and gut the large CAT in the centre as that seems to take most of the noise out in the CDTI exhaust.
    gwent
    My car has just pass the mot I have a cat fitted but no back boxes my exhaust is duplex so I got a box in the middle then straight through to the tail pipes this is a mid sport system by power flow with vxr tail pipes
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by nutron View Post
    http://www.motinfo.gov.uk/htdocs/m4s07000101.htm
    Have a read of section 7.1
    On vehicles that qualify for a full cat emissions test, check the presence of the catalytic converter.
    Mar 2011
    newcastle upon tyne
    has any one got a video ? just to see what it sounds like...
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Had a straight through on my old derv no boxes no cats nothin just piped straight out of the back two ovals one each side sounded good
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
