Thread: Auto Gearbox-poor shifting
    Regular Member millard2004's Avatar
    Luton
    confused Auto Gearbox-poor shifting
    Anybody got experience of sluggish/jerky shifting with the 6 speed auto box?
    Mines a 2.8T and has been fine but now seems very sluggish from first pull away when cold and slowing down from motorway speeds on the exit ramp it changes down really clunkyly when braking to stop?
    Any thoughts?
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    I've noticed mine isn't as smooth as it was when I first got it too. But then the ATF is due a change - could be the same for you?
    Luton
    How often does the transmision fluid need changing? I wondered if it was short of fluid?
    Jun 2011
    If I remember correctly (haven't confirmed this) it's every 4 years or 80,000 miles. I should have done mine at the last service but after all the hassle with the oil filter, I thought I'd skip it. Now I think it's badly needed.
    I could be a bit low. I think there's a how to on here somewhere.
    Jun 2011
    DP Gremlin again.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    vx say they are sealed for life uttter rubbish well worth changing it
    Devon
    Quote Originally Posted by millard2004 View Post
    Bear in mind if you just drop out what's in the pan you will only be changing half the ATF. If you want to avoid any problems with your transmission, change the ATF every 2 years.
    Luton
    confused
    What do you mean "only half the fluid" ?...by the way I like the sound of your exhaust mods,whats the Miltek look like at the rear end?
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Search my name mate there is some piks of it before and after had new tips put on aswell
    Devon
    The auto's hold about 7.5 - 8 litres of ATF. By draining what's in the oil pan you only get about 3.5 - 4 litres out. The rest is trapped inside the torque converter. The only way to change all the fluid is by pumping it out with the engine running.
  1. Poor Starting CDTI 150 Auto
    By 1075 in forum Engine & Drivetrain
    Last Post: 26th January 2013, 18:06
  2. Auto Gearbox
    By viper8 in forum Engine & Drivetrain
    Last Post: 7th March 2012, 21:12
  3. auto gearbox
    By Paddy in forum Engine & Drivetrain
    Last Post: 26th March 2011, 22:40
  4. Auto gearbox
    By vectracman in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 09:20
  5. F23 auto gearbox oil
    Last Post: 12th March 2011, 21:56
