Thread: Alternator HELP
    Full Member dezzyb66's Avatar
    Aug 2011
    carlisle
    Vehicle : Vectra c
    Engine : 1.9cdti 120
    Default Alternator HELP
    what voltage does the 1.9 cdti 120 charge at checked mine today was just hitting just above 13 volts is that ok or have i got a problem
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    can someone tell me for the 1.9cdti 150bhp please as well
    Regular Member DonnieDubh's Avatar
    Jul 2011
    Fortwilliam Highland
    My 150 cdti charges at 14.2 v on a 12v car anything over 12 is chargeing to some degree but would think 13 is on it's way out or has an earth prob .
    There's tons of threads on this on here I fitted a new 1 to mine 2 days ago as mine was chargeing at 11.3v
    Jul 2011
    Double post
    Dec 2011
    Seaham
    A good alternator should be pumping out 14.4v, this will drop slightly under load of lights, power steering etc.
    test the voltage at about 1000 rpm and not tick over.
    The only way to be sure of the condition is to have it load tested, which is normally done on a bench.
    Aug 2009
    Wakefield
    Generally you should be seeing between 13.8v and 14.4v - anything below 13.8v and I'd get it checked out.
  1. New Alternator
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 00:50
  2. which alternator
    By john1 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2011, 13:32
  3. Alternator
    By m8wos in forum Engine & Drivetrain
    Last Post: 10th December 2011, 20:54
  4. what alternator do i need?
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 14:50
  5. alternator
    By hitcho in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 21:01
