Thread: soot on side of engine block
    Apr 2011
    oswestry
    Default soot on side of engine block
    Wonder if anyone can help, just noticed a fair amount of soot on the turbo side of my engine, seems that exhaust gasses are leaking out under boost from somewhere beneath the turbo. no loss of performance, anyone got any ideas
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    What engine have you got. Could be soot from the EGR..
    Apr 2011
    oswestry
    it's the Y30DT. Had it looked at in a garage, ran a smoke test, couldn't find anything. It's very obvious the soot is being spat out at full throttle under boost. Has anyone experienced this before? I was wondering about the wastegate and whether there's a pipe underneath somewhere that's come off. all help gladly recieved.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Could be the gasket that sits between the exhaust pipe and the turbo itself that has blown. Remove the heat shield and you should see three bolts (or more, I don't remember anymore...) holding the pipe in place. HTH
    Apr 2011
    oswestry
    i shall do that tomorrow, are they easy to get at from above (if you remember). It looks mighty complicated around the turbo?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It's not the easiest job (nothing seems to be on this engine). There are 5 bolts I think, not sure if you have to remove the manifold to get to the 5th one.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Take heat shield off turbo and see. As theirs a few places it could be leaking from
    Apr 2011
    oswestry
    Just to complete this thread, the corrugated pipe from the turbo to the egr had split. i've owned this car for over year and could never get more than 35mpg, now i'm getting an easy 40 driving it hard, 45 taking it easy. amazing.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    How much did you pay to get it changed mate? Labour and parts Was it an obvious split or small one?
    Apr 2011
    oswestry
    split was on the underside of the pipe, so only visible when removed. it was quite big, about half the circumferance of the pipe. Part was 70, labour was another 60, not so bad for the result.
  1. engine block painting
    By Caveman_nige in forum Styling
    Last Post: 6th May 2012, 07:17
  2. engine block light on????
    By rab,gsi in forum Engine & Drivetrain
    Last Post: 14th December 2011, 13:43
  3. Black soot/smoke when revving the engine
    By tigro in forum Engine & Drivetrain
    Last Post: 30th October 2010, 14:41
  4. Where is VIN on engine block
    By manimal in forum Engine & Drivetrain
    Last Post: 25th October 2010, 12:44
  5. soot on engine cover
    By John35 in forum Engine & Drivetrain
    Last Post: 20th September 2007, 20:48
