Results 1 to 10 of 11
Thread: service (fuel filter)
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Default service (fuel filter)
    hi, never done a fuel filter on a vectra before herd its a ****. done one on a clio dci before was ok but had to bleed it which was a ****. anyone done this is it hard, what tools will i need?? cheers guys
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by rozzer2006 View Post
    a CDTI I take it?
    removing the filter housing from the car is easy - remove the two fuel lines by releasing the blue clips, unclip the two electrical connectors (one at the top and on at the bottom - and then puch the housing up out of the bracket.
    Where people struggle is undoing the filter housing to get the filter out. Its a screw top.. you will need to clamp the housing in a vice (or work mate between two blocks of wood) and then undo the top.
    When re-assembling, make sure you get the top tightened down with the rubber seal nicely in place otherwise when you turn the ign on you will get diesel spurting out
    A
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    yes oil burner lol, ok . will i need to bleed the ******?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Nah - they self bleed - just turn the ign on and off for 5 or so times for 3 - 5 seconds each before crancking it over.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by AntSSSS View Post
    a CDTI I take it?
    A
    Be very careful when releasing the fuel lines clips - they are very easily damaged and if you do damage them you have to replace the whole filter housing. Use two small screwdrivers, one either side to push in the spring clips and then pullout the pipes - easy enough but very fragile.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    How do you undo the top. Special tool needed ????
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by John35 View Post
    There are special tools you can buy - but if you clamp the bottom half of the housing in a vice you can unscrew the top - if your lucky by hand - but usually you need some sort of strap wrench or large grips to get it moving.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    tnx for the advice guys very helpful, sound a bit better because my clio dci was a pain had to bleed it, diesel everywhere that sort of thing lol
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    There is a special tool you can get to unscrew the lid http://www.ebay.co.uk/itm/Fuel-Filte...mod%3D15075365
    I suppose if you were doing a lot it might be worth getting one! You can improvise but the thing to remember is that the filter casing is made of a tough plastic that is quite brittle and you must treat it with kid gloves to prevent any damage especially the two fuel line connections - but easy enough to do and as already said no need to prime the system after fitting.
    Bristol
    Vehicle : CDTI 150
    There is a How 2 with pictures in the How 2 section.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Fuel filter change!! service
    By kevinmc in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 00:15
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. Fuel filter + service light
    By mr.4dil in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2008, 23:54
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
