Thread: Rust on roof (repair)
    Jul 2011
    Leeds
    Post Rust on roof (repair)
    Got some rust on the top of my car, no bigger than a 5p pence, how can I get rid without paying someone to spray my car? Got some other scratchers and white paint on the car aswel but dno if am gnu be able to do that myself........
    Jul 2011
    Leeds
    Would i just use sand paper and black auto paint for my car or is their special sand paper? Do I have to sand bigger than the area to try and get a better match?
    South east
    I think there's little chance you could do any repair that won't make it look worse than it is. If you don't have prior experience of spraying metal with rattle cans, then the roof isn't the place to start, and even a pro will have difficulty blending the new paint in with old.
    Jul 2011
    Leeds
    so do you think I should just leave the rust? just not wanting to have further problems with the rust further down the line.
    South east
    The body is galvanised, so shouldn't rust. It may be the case that the roof has been repaired in the past and that's the cause of the rust. Either way, first get a quote from a "smart repair" company such as Chips Away, as they can fix just the damaged part of the roof and blend the repair with the existing paint, whereas a bodyshop will want to paint the whole roof because they'll say they can't blend it in. If the smart repair is less than you thought it would be, Bob's your uncle. If it's more than you thought and you still want to do a DIY job, then you need to practice spraying first. I'll do a search for any past threads that explain the painting process.
    South east
    Jul 2011
    Leeds
    ok thanks will look into it. I assume that the last owner has used a roof rack and scraped the roof as the cover to the roof clips have scratches.
    Jan 2012
    largs , scotland
    i have a wee bit of rust on mine as well , from where a roof rack foot was , im just gona rub the rust down and use a touch up stick , wont look great but its better than rust , done the same to my mk3 golf on quite bad patches of rust useing black hammerite , actually looked no bad , could hardly see it
  1. DIY rust repair around filler cap
    By julian924s in forum General Motoring Chat
    Last Post: 25th July 2012, 20:50
  2. Rust?
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2011, 21:38
  3. Need some help with rust.
    By Vaux-Man-G in forum Bodywork & Interior
    Last Post: 17th March 2011, 14:40
  4. How much to repair a deep scratch on my roof
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2007, 16:02
vectra c rust roof
