Results 1 to 10 of 17
Thread: im sure ive bought a lemon! more problems
    New Member crinks85's Avatar
    Feb 2012
    high etherley
    Default im sure ive bought a lemon! more problems
    Started up from after a morning ridding the push iron and the interior heating fans went mental! They were on the off position, and after 10 seconds they went off. The buttons weren't responding so i set off home.
    About 5 miles down the road they went nuts again then went off again. Straight away I could smell this burning surgical smell and the car filled with white smoke.
    Anyone have any ideas?
    Cos im stumped.
    Sodding Typical on Sea
    Sounds like water in the firewall cowling has entered the heater and caused the resistor to burn out.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Same thing happened to me, this is what my resistor pack looked like when I took it out
    Feb 2012
    high etherley
    Not good then, thought fuses stoped this thing happening. How do you get access the area where it is? Is it a order and fit job or a mechanic thing? How did the part cost to replace it.
    Mar 2011
    Wirral
    Dead easy DIY job.
    Remove the glovebox, and it is there infront of you. The resistor pack is screwed to the bottom of the blower motor. I got a blower motor and resister pack for £80 off ebay. Think the resister pack alone is something like £211 from the stealers.
    What year is your car and do you have climate control?
    Feb 2012
    high etherley
    It's a 04 on a 53 plate. It does have aircon but never used it. Looks like I'm trawling fleabay again! Cheers for the info. Guna go check the part now. It smelt like a hospital ward! Really strange.
    Mar 2011
    Wirral
    Take your resistor pack out and check it first to make sure it has burnt out. Most likely is but don't want to waste your money and time if it's not that.
    Also clean your drain hole infront of your pollen filter to prevent it from happening again!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    dual post
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    For just aircon, and not climate, then you need this part and not the one mentioned above.
    http://www.ebay.co.uk/itm/Vauxhall-V...item563a28837f
    Verify it is the resistor pack first. It is located at the bottom of the blower assembly near the bulkhead. You will see the wires before the resistor and it just unclips and pulls out.
    There are loads on ebay, at various prices, the link was just one of them
    Feb 2012
    high etherley
    It's probably climate, as you can change the temps in passenger side while the drivers side could be higher or lower. Does that sound bout right?
  1. Hope I havnt bought a lemon
    By rimotu66 in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2012, 20:28
  2. looks like iv bought a lemon
    By wads187 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd May 2012, 23:15
  3. my last lemon
    By Guinea in forum The 'Off Topic' room
    Last Post: 11th September 2011, 22:35
  4. Finally a pic of The Lemon
    By ServerKing in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2010, 11:20
  5. Lemon Section
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2007, 09:44
vectra c heater went off after 10 seconds
