Results 1 to 10 of 15
Thread: Starting problem with z19dt engine from cold.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Default Starting problem with z19dt engine from cold.
    Hi guys. Still having this starting issue from cold. Car with spanner light still on at ignition (forever) but goes off instantly after/while starting, car chuggles when starting. This is problem started after DMF and clutch change.
    Read the injectors today and got the readings below. Is this normal?
    Cylinder 1 injector Quantity Deviation: (-2.10)
    Cylinder 2 injector Quantity Deviation: (-0.13)
    Cylinder 3 injector Quantity Deviation: (2.01)
    Cylinder 4 injector Quantity Deviation: (0.21)
    Also has code P0621- Generator Lamp "L" control circuit malfunction.
    Could this be related to the starting issue? Thanks.
    Changed so far, glowplugs, injector seals, leak off pipes, thermostat, battery.
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Have no idea about the injector results but I have done pretty much the same as you, also bought another battery for it a couple of weeks back but still seems quite tempermental. Starting to think this could be down to valve shims. Or as someone else a while back found some wear and tear on their camshaft (some kind of manufacturing defect). Apart from all that I am just as stumped as you
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    looking at that the third injector wiring needs replacing the part number from vxl for the " field remedy kit " is 93189918 and will cost about £16 or there about you will need a soldering iron too
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by Dre View Post
    That's for a z19dth 150bps engine mate. No???
    Regular Member C-Owner's Avatar
    May 2011
    South London
    "Also has code P0621- Generator Lamp "L" control circuit malfunction."
    The alternator is either low/high on voltage output or has an internal short.
    This has been know to cause cold starting problems.
    Engine : 1.9 CDTi
    Have you had the codes read?
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by lee gsi View Post
    Cleared this code and the spanner light turned off but car still struggles to start and the chugging is still there.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by C-Owner View Post
    I have always thot the alternator only kicks in after car is started to charge and replace voltage used for starting by battery. wrong???
    Battery voltage before/after starting car is 12.1/14.0volts. could there still be an alternator problem?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you cleaned the EGR and boost sensor?
    And check vac pipes for splits too
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by tony-1977 View Post
    Took EGR out yesterday and though the solenoid was ok, I took it to pieces and cleaned it. Same goes for the boost sensor.
    Not checked the vacuum pipes properly for split but might just change that incase it's a thin line split that can't be seen easily. Thanks for the suggestion.
  1. 1.9 Cdti 120 Z19DT bad starting FINALLY FIXED!!!!!!!
    By 2wheelstu in forum Engine & Drivetrain
    Last Post: 4th June 2013, 13:37
  2. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  3. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  4. 1.9 cdti Z19DT- Cold start problems..... Please help..!!!!
    By Gavin.Dring in forum Engine & Drivetrain
    Last Post: 7th August 2012, 21:25
  5. cold starting problem
    By iansfocus in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd February 2011, 16:54
z19dt injector deviation
vectra c z19dth generation l
z19dt injector readings
Generator Lamp L Control Circuit Malfunction
z19dt leak off
p0621-02 generator lamp l control circuit malfunction
wiring alternator z19dt
opel injector quantity deviation
vectra c 1.9 dt injection quantity deviation
