Thread: Slight Radiator Leak
    East Ayrshire
    Trim : SRI XP1
    Default Slight Radiator Leak
    Central heating, not the car! Fitted a new radiator in my hall as per my thread a few weeks ago. Finally got around to it this morning. I've used new tails etc on the valves and put thread tape around the thread etc, however I have a very slight leak, 1 drip every other minute or so. Everything is as tight as I can get it but it's still not right. Any suggestions?
    Dec 2011
    Seaham
    Have another go with the joints. When you put the PTFE tape on, did you wrap it so that it wouldnt unscrew the tape off when you tightened the nut? Plumbers put about a fot of tape on.
    Otherwise, I would suggest you putting on new olives and trying again?
    East Ayrshire
    Trim : SRI XP1
    I'll give it a blast. I only put a couple turns of tape on so maybe thats the problem then, Didnt think it needed much. Cheers
    Dec 2011
    Seaham
    Also hold with one set of stilsons whilst tightening the nut, then you can feel how much weight you are putting on to nip it up.
    East Ayrshire
    Trim : SRI XP1
    Already done that. Unfortunately its an 8mm inlet and outlet pipe so they bend very easily. Had to make sure I had a good grip of them
  1. 2.2 slight oil leak still.......
    By Lordish in forum Engine & Drivetrain
    Last Post: 3rd April 2012, 07:29
  2. slight oil leak
    By srikev in forum Engine & Drivetrain
    Last Post: 18th August 2011, 23:23
  3. Slight oil leak from sump plug.
    By AlexGSi2000 in forum Engine & Drivetrain
    Last Post: 11th July 2011, 22:28
  4. slight oil leak
    By BRIANE in forum Engine & Drivetrain
    Last Post: 26th July 2008, 18:17
  5. Slight oil leak, 1.9CDTi.
    By pricey in forum Engine & Drivetrain
    Last Post: 22nd May 2008, 19:28
